Sudden Power Surge - Is It Normal?
Go to page: 1, 2  Next
tuner01
Post20-01-2005, 19:16    Subject: Sudden Power Surge - Is It Normal? Quote
It's about a Volkswagen Golf A4 1.9 TDI with 96 kW (approximately 130 horsepower), manufactured in 2001.
You start in first gear and shift to second, then floor the accelerator. Between 1000 and 2200 RPM, you don't really get much power. But then suddenly it kicks in, the wheels spin, and the car takes off.
Is it normal for there to be so little power at low RPMs?
The VTG (Variable Torque Gradient) should help to partially prevent a torque dip.
In my opinion, the power delivery should be more "gradual" and not kick in so abruptly... could something be broken, or is this normal?
Translated on 28-07-2026, 22:57.
moby
Post20-01-2005, 22:24    Subject: Sudden Power Surge - Is It Normal? Quote
Hello, if it's working correctly (which isn't always the case), it suddenly starts at 1900 RPM. Of course, this also happens in first gear. If you give it full throttle in first gear, it gets even worse than in second gear (*obviously*). You have to learn how to deal with it so that the tires don't wear out too quickly icon_smile.gif.
'CU Thomas' translates to 'See you, Thomas.'
Translated on 28-07-2026, 22:59.
Günther
Post20-01-2005, 22:34    Subject: Sudden Power Increase - Normal? Quote
You start in first gear and drive slowly, then shift to second. You floor the accelerator, but between 1000 and 2200 RPM, there's not much power. But then suddenly, it kicks in – the wheels spin, and the car takes off.
Furthermore, in my opinion, the power delivery should be more 'gradual' and not start so abruptly... could something be broken, or is this normal?
Why don't you buy a 'less powerful' car, or practice using your right foot?
Günther.
Translated on 28-07-2026, 23:00.
moby
Post20-01-2005, 22:41    Subject: Sudden Power Surge - Is It Normal? Quote
The person above is right. Buy a 100 HP TDI engine. Its power delivery is more harmonious. I would never think of complaining about this characteristic. In fact, I chose this engine precisely because of it icon_smile.gif.
I also want to make sure my vehicle has sufficient power.
Translated on 28-07-2026, 23:02.
tuner01
Post20-01-2005, 23:01    Subject: Sudden Power Surge - Is It Normal? Quote
I'm not complaining, and I don't think it's bad that things are the way they are *g*... I just wanted to know if this is also normal, since I haven't driven any other comparable TDI models yet.
Translated on 28-07-2026, 23:03.
Günther
Post20-01-2005, 23:07    Subject: Sudden Power Surge - Is It Normal? Quote
I'm not complaining either, and I don't think it's bad that things are the way they are *g*... I just wanted to know if this is also normal, since I haven't driven any comparable TDI models before.
Hello.
One should adjust to the car they are going to drive.
If you had bought a Porsche, you probably wouldn't be 'alive' anymore!
Günther.
Translated on 28-07-2026, 23:04.
pschaefer
Post20-01-2005, 23:28    Subject: Sudden Power Surge - Is It Normal? Quote
Damn, now I finally understand what kind of feeling the automatic transmission gives me! icon_biggrin.gif icon_biggrin.gif icon_wink.gif
Translated on 28-07-2026, 23:05.
Günther
Post20-01-2005, 23:30    Subject: Sudden Power Surge - Is It Normal? Quote
Damn, now I finally understand the kind of feeling this automatic transmission gives me! icon_biggrin.gif icon_biggrin.gif icon_wink.gif
Build that 'thing'!
WarLord
Post21-01-2005, 17:12    Subject: Sudden Power Surge - Is It Normal? Quote
@tuner01
It should have started abruptly at 1,500 RPM. What about in third gear? Does it start late there too, or sooner?
Best regards, WarLord.
Translated on 28-07-2026, 23:06.
Polo2004
Post21-01-2005, 19:50    Subject: Sudden Power Surge - Is It Normal? Quote
So, as WarLord mentioned, it usually works well in the second gear, especially in the lower RPM range. It would be interesting to see what happens with the other gears, for example, in fifth gear.
Best regards, Christian.
Translated on 28-07-2026, 23:07.
Hati
Post21-01-2005, 20:33    Subject: Sudden Power Surge - Is It Normal? Quote
Hello tuner01.
Okay, just forget everything that Moby and Günther wrote for now.
The PD-TDI engine should have good power output even at 1500 rpm, especially the 96 kW version.
The AXR engine (74 kW; mine) also pulls strongly from as low as 1500 rpm. Unfortunately, I've had the problem several times in recent weeks that my AXR engine didn't produce any noticeable power until 2000 rpm. This lack of power was particularly pronounced in the higher gears. After replacing the mass airflow sensor and the turbocharger pressure control valve (I still have warranty until 09/2005), I took the car back to VW today. The diagnostic tests finally revealed a faulty turbocharger. During the diagnostic process (the engine is held at 1400 rpm via the VAS 5052), it wasn't generating enough pressure when the variable turbine geometry (VTG) was fully activated.
Since your response behavior exactly matches mine, I would investigate for a fault in the VTG area: measure the vacuum of the tandem pump, check the boost pressure control valve, look for leaks in the 'hosing' to the VTG, check for sticking or jerky VTG operation, and measure the boost pressure. For the latter, a diagnostic tool (available here in the shop; @Rainer, will I get a discount now icon_razz.gif) can help you.
Translated on 28-07-2026, 23:09.
moby
Post21-01-2005, 21:28    Subject: Sudden Power Surge - Is It Normal? Quote
Hello Hati,
I myself drive an A3 TDI with 131 horsepower and have driven it for 28,000 kilometers. I've also driven about 10 other vehicles with a 131 horsepower TDI engine. None of them start accelerating forcefully below 1900 RPM.
I was just talking to a colleague on the phone, and he told me that his A3 TDI with 131 horsepower also starts boosting at around 1900 RPM. He's never had any issues with it, and everything is fine for him. I've driven several other TDI models with over 100 horsepower in Polos, Golfs, and A3s, and I can confirm that they all start boosting around 1900 RPM as well.
Translated on 28-07-2026, 23:11.
Hati
Post21-01-2005, 22:31    Subject: Sudden Power Surge - Is It Normal? Quote
@Thomas.
Ask Bertil when his AXR will become strong...
You can test drive the new loader next week if you like.
Translated on 28-07-2026, 23:13.
tuner01
Post22-01-2005, 14:13    Subject: Sudden Power Surge - Is It Normal? Quote
Hati wrote:
Hi tuner01.
Since your response behavior exactly matches mine, I would investigate for a fault in the VTG area: measure the vacuum of the tandem pump, check the boost pressure control valve, look for leaks in the "hosing" to the VTG, check for sticking or jerky VTG operation, and measure the boost pressure. For the latter, a diagnostic tool (available here in the shop; @Rainer, will I get a discount now icon_razz.gif) can help you.
Thank you for your detailed response. I will probably build one of those diagnostic devices myself soon (in the worst-case scenario), and then try to verify the things you mentioned.
Translated on 28-07-2026, 23:14.
Hati
Post22-01-2005, 15:02    Subject: Sudden Power Surge - Is It Normal? Quote
@moby
According to the torque curve, the ASZ engine already produces 250 Nm of torque at 1500 rpm and a maximum torque of 310 Nm at 1900 rpm. This level of torque should therefore provide adequate acceleration even at 1500 rpm. If not, there is likely a problem.
Translated on 28-07-2026, 23:17.
cetano
Avatar-cetano
Post22-01-2005, 15:54    Subject: Sudden Power Surge - Is It Normal? Quote
Okay, I understand. Please provide the German text you want me to translate into English. I will only provide the translation.
Kfz-Prüfstelle des TÜV Rheinland/FSP Saalfelder Höhe in Thüringen im grünen Herzen Deutschlands.
Wir lieben Diesel, vor allem alte..
Sommer: Oldtimer W124 2,5 Saugdiesl 90 PS Bj 87, Winter: Golf4 4Motion TDI AGR
Back to top Profile PM Email
No new posts Stunning performance drops at 1Z Diesel Engine Technology
No new posts Uneven Performance: Causes and Solutions Diesel Engine Technology
No new posts Golf 1.9 TDI ASZ - Insufficient power delivery Upload
No new posts Weak performance after ESP 2.5 TDI adjustment Diesel Engine Technology
