V6 TDI Valve Cover Gasket Replacement Time
quattrotdi
Post11-02-2005, 13:38    Subject: V6 TDI Valve Cover Gasket Replacement Time Quote
'Surely someone among you works at Volkswagen or Audi.'
Could you please check on the AFB-V6 TDI?
'Thank you very much.'
Translated on 03-08-2026, 11:47.
CheBu
Post11-02-2005, 15:02    Subject: V6 TDI Valve Cover Gasket Replacement Time Quote
According to the ATRis technique (Stahlgruber), the estimated time required is 2.5 hours. This applies to an Audi A6 (4B, C5) with a 2.5 TDI engine.
Stefan.
Translated on 03-08-2026, 11:48.
quattrotdi
Post11-02-2005, 15:18    Subject: Best German Coffee: Buy Online & Enjoy! Quote
'Thank you!'
No new posts Glow Plug Replacement: 2.0L TDI 16V Troubleshooting & Guides
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Ignition Switch Replacement VW Golf 3 Troubleshooting & Guides
No new posts Thank you for the LMM tip Diesel Engine Technology
No new posts Switch LMM: How to Change Your LMM Diesel Engine Technology
No new posts ESP Replacement: Simmering Guide & Tips Diesel Engine Technology
No new posts Water Pump Replacement: When to Change at 90,000 Miles? Diesel Engine Technology
