Golf 3 1.9 TDI: Glow Plugs Not Working?
Shelby
Post24-08-2004, 0:51    Subject: Golf 3 1.9 TDI: Glow Plugs Not Working? Quote
Vehicle: Volkswagen Golf 3, 1.9 TDI, 75 hp.
PROBLEM: It no longer ignites properly, which makes it start very poorly.
INFO: Spark plugs were replaced 1 year ago.
- The indicator light for the heating function shows that everything is normal, as if it were working.
- According to the glow control system, there is no voltage applied to the glow plugs during the preheating process.
- The fuse for the glow plug system in the engine compartment has not blown.
- The other fuses in the car are also all okay.
Please, please help me, I have no idea what could be causing this.
'Possibly the control unit, which shows no visible damage from the inside or outside, but is very expensive. It could also be the glow plug relay, but I haven't been able to identify it. When it was working, you could hear a relay clicking when the glow plug indicator light went out, but that sound is no longer present.'
Translated on 22-09-2026, 5:27.
DocSnydor
Post24-08-2004, 8:41    Subject: Golf 3 1.9 TDI: Glow Plugs Not Working? Quote
Even a 1.9 TD (AAZ ???) should start well in these temperatures without glow plugs. Don't focus solely on the glow plug system when troubleshooting... Search the forum for starting problems. It could be caused by many different things.
Translated on 22-09-2026, 5:29.
Post24-08-2004, 10:08    Subject: Golf 3 1.9 TDI: Glow Plugs Not Working? Quote
"Something's not right with my AAZ engine... Is this the crankshaft bolt for the timing belt pulley?"
Translated on 22-09-2026, 5:30.
Post24-08-2004, 11:23    Subject: Golf 3 1.9 TDI: Glow Plugs Not Working? Quote
Do we really want to be like that icon_smile.gif?
http://home.arcor.de/sgrafen/salatoel/kw_schraube/kw_schraube.html
Gremlin
Post24-08-2004, 11:39    Subject: Golf 3 1.9 TDI: Glow Plugs Not Working? Quote
Even a 1.9 TD (AAZ ???) should start well without preheating in these temperatures. Don't focus solely on the glow plug system when troubleshooting... Search for 'starting problems' in this forum. It could be caused by many different things...
It's currently 8°C (46°F) at our place in the early morning.
The three-chamber diesel engines in the yard don't make a sound other than white smoke without preheating.
(The TDI faction always does that.)
'The only thing to do is to check the heating system. Check the temperature sensors, etc. If necessary, trace the wiring to find the relay... Unfortunately, I don't have any G3 schematics available.'
CU Gremlin.
Translated on 22-09-2026, 5:31.
DocSnydor
Post24-08-2004, 12:03    Subject: Golf 3 1.9 TDI: Glow Plugs Not Working? Quote
Sorry, I was still expecting summer icon_cry.gif (Yes, we're still having summer).
Translated on 22-09-2026, 5:32.
dieter
Karma: +13 / -0   Thank you, like it!
Post24-08-2004, 13:14    Subject: Golf 3 1.9 TDI: Glow Plugs Not Working? Quote
Are you sure the fuse is okay? Sometimes they can have a hairline crack right next to one of the screws, which you can't see.
If you haven't already, be sure to remove it.
Greetings.
dieter
T3 syncro 16 AFN
Translated on 22-09-2026, 5:33.
Shelby
Post24-08-2004, 20:23    Subject: Golf 3 1.9 TDI: Glow Plugs Not Working? Quote
Okay, I'll remove the fuse again and take a look at it! But as I said, I no longer hear the relay clicking once the preheating indicator light goes out. According to VW, it's the control unit, which costs 170€. But I've looked inside that part, and I can't see anything wrong.
Where can I find plans for my slingshot, or does anyone else have something like that?
joergs
Post24-08-2004, 20:39    Subject: Golf 3 1.9 TDI: Glow Plugs Not Working? Quote
Even if you can't see anything obvious, a defect shouldn't be ruled out, right?
Find the relay, check if there's voltage reaching it. If the relay doesn't engage, either the relay itself or a fuse protecting it is faulty. If it does engage, the strip fuse is likely defective. If no voltage reaches the relay, then the suspicion that there's a problem with the VW's electrical system is probably correct. Check all of this first, before we start making wild guesses!
Translated on 22-09-2026, 5:34.
Shelby
Post24-08-2004, 21:02    Subject: Golf 3 1.9 TDI: Glow Plugs Not Working? Quote
Thank you very much, I will check everything tomorrow! I will write to you tomorrow with my new findings icon_eek.gif.
Translated on 22-09-2026, 5:35.
gerbi
Post24-08-2004, 21:04    Subject: Golf 3 1.9 TDI: Glow Plugs Not Working? Quote
VW is replacing control units with great enthusiasm (little work, lots of money...). As joergs says, it's best to measure the system to narrow down the source of the problem.
PrivatBereich
Post24-08-2004, 21:05    Subject: Golf 3 1.9 TDI: Glow Plugs Not Working? Quote
@Shelby:
Please also check your emails.
Translated on 22-09-2026, 5:36.
Shelby
Post24-08-2004, 21:13    Subject: Golf 3 1.9 TDI: Glow Plugs Not Working? Quote
I just finished reading that! Great description! I only have one more question: which relay is used by the engine control unit for the glow plug system? There are so many icon_sad.gif.
I only know which one is the flasher relay!
gerbi
Post24-08-2004, 21:20    Subject: Golf 3 1.9 TDI: Glow Plugs Not Working? Quote
It should be located at relay position 12 (number 102, 103, 104, or 142).
Translated on 22-09-2026, 5:37.
Shelby
Post26-08-2004, 11:46    Subject: Golf 3 1.9 TDI: Glow Plugs Not Working? Quote
I did some measuring and eventually replaced relay 104 in slot 12, and now the car is working completely again, so it's running smoothly like a clock. icon_biggrin.gif
Thank you very much for your help, which was very beneficial! Thank you, thank you.
ps: The relay cost me 20€; at VW, they wanted to sell me a new control unit, which would cost around 180€. icon_eek.gif
I guess I got away with it again this time icon_biggrin.gif.
ab_tdi
Post09-02-2005, 19:38    Subject: Golf 3 1.9 TDI: Glow Plugs Not Working? Quote
I had the same problem, but the cause was different.
'When it was cold, my Golf 3 TDI (90 hp, manufactured in 1994) started very poorly.'
(The starter motor kept turning and turning). After a few seconds (sometimes longer),...
Occasionally, a puff of smoke would come out of the exhaust, and then the engine would sputter for a while.
It wasn't running smoothly at all for the first few seconds, but then it started working normally.
I then had all the glow plugs replaced at the workshop, which cost...
This was supposed to be the standard solution for this problem, but it was useless.
Whether the engine was warm or the outside temperature was warm, it started without any problems.
After some measurements, I discovered that the glow plugs had a connector attached to them.
No voltage was detected during the preheating process.
Solution at my place:
In the fuse box located under the steering wheel, you can see all sorts of things.
The fuse you're looking for is a 50A fuse located in the upper right corner, behind the relay labeled '21'.
hidden (you can actually only see it if you look at the fuse box from a certain angle).
Befestigung löst und ein bisschen dreht). This one was broken.
The whole thing had also quite confused me, because there was something in the engine compartment, below the...
In the middle of both windshield wipers, which is also where the glow plug control unit is located.
another backup is in place.
Translated on 22-09-2026, 5:40.
No new posts DPF not regenerating Troubleshooting & Guides
No new posts CR-TDI V6 2.7L: Adjustment Channels Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Not LLM: Poor Performance Explained. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts duesentausch NHG - need help Diesel Engine Technology
No new posts Ford Galaxy: Limp Mode - Get Help Now! On-Board Diagnostics (OBD)
No new posts Crazy Story - Don't Laugh! Share Your Opinions Diesel Engine Technology
No new posts A4 B7 Glow Plug Test: Yes or No? Load Check On-Board Diagnostics (OBD)
