To get it out of the way, I have already used the search function.
I built the adapter according to the minimal circuit diagram.
http://www.dieselschrauber.de/Adapter%20Standard.png
I used the ILD74 as an optocoupler; the transistors are 2N3904.
(I ordered and assembled everything according to the instructions from: hal9000.vc-graz.ac.at...)
I've already checked the circuit, and it seems correct. The problem is that the adapter isn't recognized by either VAG-COM 311.2 or 409.0. I've also already replaced R7 with a 10kOhm resistor, but the problem persists.
Please provide the text you would like me to translate from German to English.
Does the VAG-COM adapter test require any specific baud rates, KW2 delays, etc. to be configured in order for the adapter to be recognized?
Does the OBD cable need to be connected to the vehicle (due to battery voltage)?
2.
Is it really advisable to build such a simple adapter? I've also read the technical article on this page, which states that this adapter is not ideal. Are the optocouplers I used "good," or are other types more recommended?
Are there any other tricks or things to keep in mind when setting up the circuit?
4.
I want to solder in an LED that indicates whether there is voltage coming from the car. Do I need to solder the LED to pin 16 and pin 4 on the OBD connector, or to pin 16 and pin 5?
I'm asking because I read about pin 4, but isn't pin 5 actually the vehicle's ground? Pin 4 is just a signal ground...
And one more thing.
I also intended to build the "Worst-Case Design" version 4.0. Has anyone had experience with this adapter? What optocouplers and transistors did you use?
5. How can I determine if a car uses 2K-Lines or K-Lines? Is it simply a matter of trying both switch positions with the adapter?
Thank you in advance
