VAG-COM fails to connect
sir.robert
Post12-02-2005, 19:33    Subject: VAG-COM fails to connect Quote
Hello!
I borrowed a VAG-COM device from a friend. Since I'm completely new to the program, I'm not familiar with it. My problem is that it's not establishing a connection or finding any control units. I drive a Passat from 2001 with an AWX engine. It works perfectly on my colleague's Passat, which I think is from 1998. What's the problem?
Thank you in advance for any helpful contributions.
Robert.
Post12-02-2005, 19:59    Subject: VAG-COM fails to connect Quote
Have you read this before?
Uwe@Ross-Tech
Post13-02-2005, 16:00    Subject: VAG-COM fails to connect Quote
What kind of interface?
Manufacturer, model?
Is a USB-to-Serial converter being used?
What kind of computer?
Manufacturer, model, CPU, RAM, Windows version?
Which version of VAG-COM?
Version is a number, not 'The German' or something like that.
-Uwe-
Post15-02-2005, 11:17    Subject: VAG-COM fails to connect Quote
I don't believe this topic brings much new information, except that almost all adapter hardware that isn't sold by VAG-COM distributors isn't very good, or can only be used with versions of VAG-COM that are already outdated.
Please don't blame VAG-COM, but rather the seller of the adapter hardware.
You can easily avoid such problems by purchasing quality products from a reputable distributor.
No new posts 4Motion Not Working: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AVF facing massive problems, no performance Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air Suspension Failure: Allroad Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts HEX-NET: No Wi-Fi connection On-Board Diagnostics (OBD)
No new posts VAG COM: No Connection T5 2008 (German) On-Board Diagnostics (OBD)
No new posts VAG-COM Connection Issues Near Munich? On-Board Diagnostics (OBD)
No new posts OBD2 Check: No Connection to VW T5 Multivan? On-Board Diagnostics (OBD)
