ECU Data Blocks: What You Need to Know
Smilinged
Post24-02-2005, 12:16    Subject: ECU Data Blocks: What You Need to Know Quote
Measurement data blocks in the control unit?
Hi everyone.
I was wondering if there might be a list or even a book that explains the individual measurement blocks, from 1 to 256 or beyond.
I mean this applies to other control units as well, not just the engine control unit.
Translated on 15-10-2026, 12:34.
Theresias
Post24-02-2005, 12:29    Subject: ECU Data Blocks: What You Need to Know Quote
Listen... Partially...
Which vehicle, which control units? Part numbers?
Translated on 15-10-2026, 12:35.
Smilinged
Post25-02-2005, 22:21    Subject: ECU Data Blocks: What You Need to Know Quote
Engine control unit, ABS control unit, comfort control unit, instrument cluster.
Best for VW and Audi.
if possible
Theresias
Post25-02-2005, 22:23    Subject: ECU Data Blocks: What You Need to Know Quote
Welches Fahrzeug? Part numbers?
There are no general lists available, but it is sometimes possible to create lists specific to certain control units.
Translated on 15-10-2026, 12:36.
tuner01
Post27-02-2005, 11:14    Subject: ECU Data Blocks: What You Need to Know Quote
I'm just hanging around, wondering icon_wink.gif.
I need the list for a Golf IV Cabrio, model year 2001.
sunny
Post27-02-2005, 14:20    Subject: ECU Data Blocks: What You Need to Know Quote
hi,
and is there anyone else who might need such a list for a Seat Ibiza, type 6K1, 1.9 TDI, manufactured in November 1998, engine code AFN icon_biggrin.gif
Translated on 15-10-2026, 12:37.
Theresias
Post27-02-2005, 15:24    Subject: ECU Data Blocks: What You Need to Know Quote
Specifically, which control units and which part numbers?
...is there anyone else who might need such a list for a Seat Ibiza, type 6K1, 1.9 TDI, manufactured in November 1998, engine code AFN icon_biggrin.gif.
That's a bit more concrete, but it's still not really exciting. icon_wink.gif
If you want us to help you, you need to provide specific information by reading out and posting the part numbers using VAG-COM.
Translated on 15-10-2026, 12:38.
sunny
Post27-02-2005, 15:44    Subject: ECU Data Blocks: What You Need to Know Quote
028 906 021 EK
and 1.9L R4 EDC G00SG 1438.
and I also need the corresponding labels in German (for the 409.1 shareware version), and a small instruction on where I need to copy them (I'm an IT novice icon_redface.gif).
Translated on 15-10-2026, 12:39.
Post27-02-2005, 18:57    Subject: ECU Data Blocks: What You Need to Know Quote
@ Sunny
icon_evil.gif Please use the search function.
"Label files" can get you surprisingly far.
including, among other things, the file being searched for.
Where does it go: It's quite complicated... to the other label files, where else would it go?
Translated on 15-10-2026, 12:40.
Theresias
Post27-02-2005, 19:03    Subject: ECU Data Blocks: What You Need to Know Quote
What to do with it: It's quite complicated... put it with the other label files, where else would it go.
It is recommended that you save/copy your own/additional files to the '/labels/user/' subdirectory within the VAG-COM folder, unless otherwise specified. This folder is searched first, before the folder for the specific distribution and the main '/labels/' directory.
Translated on 15-10-2026, 12:41.
Post27-02-2005, 19:04    Subject: ECU Data Blocks: What You Need to Know Quote
Okay, I'm ready. Please provide the German text you want me to translate.
Theresias
Post27-02-2005, 21:44    Subject: ECU Data Blocks: What You Need to Know Quote
028 906 021 EK
http://download.openobd.org/labelfiles/02-01.lbl
http://download.openobd.org/labelfiles/german/028-906-021-AFN.lbl
The file for the AFN has been lying around for a while, but no one has asked for it yet.
@Rainer, I took the liberty of partially using your target values.
It's quite possible that the 409.1 error is occurring due to a problem with the redirection.
This issue was fixed in a later version, and there are no problems with version 500.x.
Possibly, therefore, rename the actual label file accordingly.
...and I would also need appropriate labels in German (for the 409.1 shareware version)...
For the engine control unit (ECU), see above. Which other parts do you need?
...and a small guide on where I need to copy and paste it (I'm an IT novice icon_redface.gif)
Translated on 15-10-2026, 12:43.
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Measurement data blocks 001-137 On-Board Diagnostics (OBD)
No new posts VW TDI Engine Sensors A4 2001+ - AWX/AVF On-Board Diagnostics (OBD)
No new posts Urgently looking for {BLOCK TYPE} blocks... 2.5tdi AEL an... On-Board Diagnostics (OBD)
No new posts ECU 1Z for AHU Engine: Compatibility & Info On-Board Diagnostics (OBD)
