T5 Engine Control Unit (ECU)
chli1976
Post24-02-2005, 11:53    Subject: T5 Engine Control Unit (ECU) Quote
Hello.
I need a label file for a T5 model, year 2004, 2.5 TDI AXD, 130 HP.
Control unit No. 070 906 016.
I had my engine control unit (ECU) tuned through the diagnostic socket.
I also saved an error.
Control unit 2 for radiator fan defective.
P1949-00-Interrupted.
I have deleted the errors.
"Lately, the engine hasn't been running as well. The performance is like it was before the tuning."
The company told me that I shouldn't install any software updates, otherwise the performance boost will be lost.
I've only cleared the error codes with VAG-COM, and since then, the "normal power" has been restored.
Can anyone tell me if there might be a connection here, or if anyone has a label file?
Okay, here's the translation:
Thank you.
Christian.
Translated on 14-10-2026, 23:48.
Uwe@Ross-Tech
Post24-02-2005, 15:05    Subject: T5 Engine Control Unit (ECU) Quote
When errors are deleted, various learned values are also erased, but the engine control unit should relearn these values after a short period of driving. However, if an engine doesn't run correctly after clearing errors and learned values, it usually means that a sensor is no longer providing the correct readings, or that some parameters in the chip tuning are not set correctly.
-Uwe-
Translated on 14-10-2026, 23:50.
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Engine Control Unit Errors: 2.5L V6 TDI (No Delete) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Control Unit 1Z Diesel Engine Technology
No new posts A6 C4 TDI Engine Control Unit On-Board Diagnostics (OBD)
No new posts ECU for AHY/AXG Engine: Find the Right One On-Board Diagnostics (OBD)
No new posts ECU Replacement: AXR Engine Control Unit On-Board Diagnostics (OBD)
