What are some low-cost options for reading OBD data?
Hoshi164
Post22-02-2005, 13:12    Subject: What are some low-cost options for reading OBD data? Quote
Hi forum!
I drive a T4 TDi, manufactured in 1999.
I would like to discuss the existing diagnostic interface.
Read out any existing error codes and, if necessary, reset them.
Could this be done using a standard terminal program, or would something else be required?
Am I misunderstanding the complexity?
Thank you and best regards,
Eric.
Rudi
Post22-02-2005, 13:35    Subject: What are some low-cost options for reading OBD data? Quote
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission: No Rebuild Needed (01K-01F) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B ABS FS reading not possible! On-Board Diagnostics (OBD)
No new posts BMW 330 Touring E46 - Can it be read out with VCDS? Parki... On-Board Diagnostics (OBD)
No new posts Question: Info on CAN-Bus Interface RKS+CAN variants On-Board Diagnostics (OBD)
No new posts Is it possible to perform a turbo replacement for a 1.9 d... Diesel Engine Technology
