Cabrio Ride: 10 Cent? (Possible?)
caravanatic
Post24-02-2005, 19:46    Subject: Cabrio Ride: 10 Cent? (Possible?) Quote
hello everyone,
I traded in my fairly nimble A4 for an Audi 80 cabrio icon_biggrin.gif Ahhu, and now I want to increase the rather meager 90 horsepower. Unfortunately, I discovered that the connector for the fuel injection pump is round and has 7 pins icon_confused.gif.
I've already tried using the search function, but I couldn't find anything relevant.
Okay, so my question is: Is it possible to adjust the settings by 10 cents, or are there any power boxes available for this connector?
Thank you in advance.
Translated on 16-09-2026, 1:40.
Post24-02-2005, 20:15    Subject: Ahu Cabrio: 10 Cent Possible? Quote
caravanatic wrote:
Unfortunately, I discovered that the connector for the fuel injection pump is round and has 7 pins. icon_confused.gif
Circleround??
That was the characteristic feature of the first TDIs with potentiometer-based rotary variable geometry (RWG), if I recall correctly icon_question.gif.
However, even a 1998 TDI should have an HDK rotary vane pump, so 10c should be possible – if you can find the right cables.
Translated on 16-09-2026, 1:42.
Post25-02-2005, 8:22    Subject: Cabrio Ride: 10 Cent? (Possible?) Quote
Well, I think he's referring to an 8-pin connector where only 7 pins are actually used.
It should look like this (warning: 450 kb).
http://www.luxus-wg.de/~martin/auto_bilder/DSC01734.JPG
Translated on 16-09-2026, 1:43.
Post25-02-2005, 8:32    Subject: Cabrio Ride: 10 Cent? (Possible?) Quote
Such a picture is also included in the technical article.
I find it hard to believe that an AHU would have a round, screw-on connector for the potentiometer-controlled circulating pump.
The AHU arrived in early 1996, and the Poti pump was discontinued around 1994.
Perhaps the previous owner modified something.
How do you know that it is an AHU?
Can you provide photos?
caravanatic
Post25-02-2005, 9:59    Subject: Cabrio Ride: 10 Cent? (Possible?) Quote
It's a completely original AHU engine. The connector is round and has 7 pins, unlike the one shown in the picture. The pictured engine is a 94, but the B4 engine was modified, and the AHU was produced in the Cabriolet until 1999.
Translated on 16-09-2026, 1:44.
Hati
Post25-02-2005, 12:16    Subject: Cabrio Ride: 10 Cent? (Possible?) Quote
Okay, 10 cents is fine. I even have a matching plug here.
http://home.tiscali.de/palmstrollo/images/im003266klein.jpg
Please send me a private message if it turns out to be THAT plug.
Translated on 16-09-2026, 1:45.
No new posts A4 8E2/8E5 - Possible various error memory messages Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to install a G40 engine without replacing ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission: No Rebuild Needed (01K-01F) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is it possible to perform a turbo replacement for a 1.9 d... Diesel Engine Technology
No new posts TDI Coolant Temp Sensor for Audi Convertible Upload
No new posts Golf Cabrio Performance Issues: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Audi Cabrio hidden control unit On-Board Diagnostics (OBD)
