Future TDI engines
Stefan.TDI
Post05-08-2002, 22:20    Subject: Future TDI engines Quote
Does anyone here know any details about upcoming TDI engines? Apparently, a 2.0-liter 16V engine with 136 horsepower is supposed to be released in the fall. Does anyone know more details?
Stefan.
DIDI
Post06-08-2002, 21:28    Subject: Future TDI engines Quote
Okay, bitte gib mir den deutschen Text, den du übersetzt haben möchtest. Ich werde dir dann drei verschiedene englische Übersetzungen liefern.
115 hp, 150 hp, and 180 hp.
More information can be found here:
http://www.tuneline.at/news/110kWPD/110kWPD.htm
No new posts VTG Adjustment for VAG TDI Engines Technical Articles
No new posts DIY solution for starting engines with VP 37 Troubleshooting & Guides
No new posts VAG Engine Specs: Dimensions & Wear Limits Technical Data
No new posts Förderverlauf bei PD-Motoren? Diesel Engine Technology
No new posts Motorentausch 2er CAN Motoren On-Board Diagnostics (OBD)
No new posts Standheizung bei PD-Motoren Diesel Engine Technology
No new posts 30c-Tuning Idea for PD Motors Diesel Engine Technology
