Phaeton Repair: 3D2 Seat Wiring Issue (Solution)
Post10-03-2005, 15:28    Subject: Phaeton Repair: 3D2 Seat Wiring Issue Quote
Author: Michael II.
For Phaeton vehicles equipped with an 18-way seat system (part number WSK), there is a possibility that, due to improper securing to the system and damage to the seat wiring harness, the wiring may come into contact with seat frame components.
Solution:
The following work must be performed on both front seats.
Extension of the rear headrest cover for both front seats.
Door sill protector adhesive pads, part number 3B0 971 882, sold individually, each measuring 90 mm.
Divide A and a 40 mm piece into smaller portions.
Adjust the lumbar supports all the way up and forward.
One of the 90 mm A-pieces is located behind the cable conduit and extends to its full length.
Insert the clip and then attach it to the struts of the lumbar support.
Warning! Ensure the edges of the edge protector are properly folded over.
One of the 40 mm B-shaped pieces was placed vertically, over the edge of the seat frame, in the designated area.
The adhesive is stuck to the side airbag hose.
Warning! The edge of the seat frame must be completely...
to be covered.
A written customer notification is not planned.
Please provide the German text you would like me to translate.
Bye.
Michael.
Translated on 30-09-2026, 12:51.
Ratings - Phaeton Repair: 3D2 Seat Wiring Issue
No new posts Phaeton Noise: Front Axle 3D2 Diagnosis Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Werkstattaktion Riemenscheibe, A4 66 und 81 KW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Software error in the instrument cluster - workshop action Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Phaeton 3.0 TDI Engine: CARA Code Details Diesel Engine Technology
No new posts Problem mit Fahrwerk Phaeton On-Board Diagnostics (OBD)
No new posts 3.0 TDI V6 VW Phaeton Engine Code CARA Diesel Engine Technology
No new posts Phaeton GP3 ADR Emergency Shut-off Switch (F317) Test Ins... Electrical Systems, Vehicle Electronics, Multimedia
