Ventoman wrote: |
Hi!
I have two questions.
1.) I think my mass airflow sensor (MAF) is broken. How can I measure (or have measured) whether it is actually broken? |
Hi.
As an
approximate way to determine if the MAF sensor is faulty or working, you can tap into connector pin 6 of the MAF sensor connector, extend the wire into the passenger compartment, and connect a voltmeter to ground (e.g., the cigarette lighter) there.
To be on the safe side, the internal resistance of the measuring device should be in the range of 100 kOhms or higher. Therefore, it's best to use a digital multimeter (which usually has 1 MOhm or more).
The most interesting measurement is usually the one taken at full load, because it's directly related to the fuel injection limit, which significantly affects the engine's power output.
Okay, with a warmed-up engine, perform a full-throttle acceleration to 4000 rpm (preferably in 3rd gear or higher). During this process, the voltage should, as far as I know, increase to around 4.5 volts. Experts in lambda sensors may want to correct this value.
Unfortunately, insufficient boost pressure can also reduce the mass airflow sensor (MAF) voltage, thereby simulating a MAF sensor defect, even though the sensor itself is functioning correctly. Therefore, it is highly recommended to measure the boost pressure simultaneously.
