AFN: Emergency Mode Activated
Werner
Post18-08-2002, 18:43    Subject: AFN: Emergency Mode Activated Quote
Hello everyone,
'I've been experiencing a recurring issue over the past few days where the system enters emergency mode (which is clearly visible on the MFA's current power consumption display). When I read the error logs, it showed:'
00575 Intake Manifold Pressure
17-10 Control difference, intermittent.
Now the question... how does he know that? Obviously, the boost pressure is being compared to something icon_confused.gif.
I've already checked the cables (for the combined pressure/temperature sensor).
Vehicle: Passat Variant, engine code AFN, manufactured in 1998.
Thank you and best regards.
Werner.
Translated on 06-09-2026, 10:07.
Post18-08-2002, 20:12    Subject: English Grammar Mistakes: Common Errors Explained Quote
Hi.
In German, your error is likely called "intermittent boost pressure differential."
If it leads to an emergency shutdown, the pressure is usually too high.
The cause is often a jammed VTG mechanism (see entry in the error database).
It could also be due to clogged or leaky control hoses, or a defect in the boost pressure solenoid valve...
Translated on 06-09-2026, 10:08.
Werner
Post19-08-2002, 11:30    Subject: SEO: "Best German Translation Services | Affordable" Quote
Hello Ulf,
So, the value to be set (theoretically calculated) is compared with the value achieved icon_wink.gif.
Then I guess I'll have to check the adjustment.
Thank you for the tip.
Werner.
Translated on 06-09-2026, 10:09.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Touareg, Transmission in Emergency Mode Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG Issues: Emergency Mode, Intake Manifold Pressure Regu... Troubleshooting & Guides
No new posts LOG AFN-Emergency Mode Upload
This topic is locked, you cannot edit or reply. Emergency Mode at 160 Diesel Engine Technology
No new posts T5 Emergency: 2.5 BPC Mode Activated Diesel Engine Technology
No new posts T5, 2,5 Emergency mode BPC Upload
