AJM: Torque Map Explained Again
herwigw
Post27-05-2005, 13:52    Subject: AJM: Torque Map Explained Again Quote
Title: MKB AJM: Request for VAG-COM logs of control module 08.
Hello fellow DIY enthusiasts,
Since my Bora is still experiencing some irregular acceleration,
I would like to address the owners of Golf or Bora vehicles.
Those who have an AJM, please post MWB 08 logs or send them to me if you happen to have them icon_smile.gif.
By the way, I'm currently mainly interested in the logged torque limitation.
because I am trying to find the cause of the inconsistent behavior of the line.
Therefore, it doesn't matter if, at the time the log was created, you were experiencing other issues, such as problems with the mass airflow sensor.
The turbocharger or boost control system, which should not affect the torque limiting line, were defective.
Have a nice weekend!
herwig
EDIT 05.31: Hasn't even a small log been found in your attics and basements? icon_cry.gif
Searching through dusty folders can also be tedious icon_wink.gif.
I'd like to try again with a less demanding request; I'm starting to think that troubleshooting is becoming a constant preoccupation for me.
If it's truly a correction due to an overload protection that's distorting my torque curve, /viewtopic.php?t=9583
For example, the altitude correction – as Ulf suspects – or the limitation due to an excessively high intake air temperature: What should I be looking for?
Even with two minutes of full throttle in fourth gear, the intake air temperature can only be brought just above 40 degrees Celsius compared to the outside temperature, and the ambient pressure reading reliably displays the actual outside pressure as reported by the weather service.
Have you ever encountered engine control units (ECUs) that malfunctioned without any sensor defects and without any error codes, and if so, how can you identify the cause?
fg
herwig
Translated on 14-10-2026, 16:20.
CheBu
Post02-06-2005, 8:06    Subject: AJM: Torque Map Explained Again Quote
A standard dynamometer graph of an AJM engine with a Digi-Tec chip probably won't be helpful to you. If it does, let me know...
Stefan.
Translated on 14-10-2026, 16:24.
Post02-06-2005, 8:53    Subject: Torque Map Analysis: A Closer Look Quote
herwigw wrote:
So, if it's actually a correction due to an overload protection that's distorting my torque curve, /viewtopic.php?t=9583
So, for example, the altitude correction - as Ulf suspects - or the limitation due to a too-high intake air temperature: What should I look for?
"First, compare the trend of your tachometer readings in the log with my diagram in the other thread."
If your logs are located below the chart, there is a suspicion of an emergency stop function.
It could also be caused by excessively high water temperatures, but I'm not an expert on that.
Even with 2 minutes of full throttle in the fourth gear, the intake air temperature can only be brought just above 40 degrees Celsius compared to the outside temperature, and the value for the ambient pressure reliably shows the actual outside pressure according to the weather service.
To limit the scope from the perspective of LLT:
It only affects the boost pressure in my turbocharger system above approximately 75°C (as far as I can tell from the logs), but it doesn't change the torque.
At full throttle at 3000 rpm, my lambda value is still about 35,000 points lower, so a torque reduction due to the lambda value (perhaps the AJM engine is programmed differently) would likely only kick in at higher RPMs.
Translated on 14-10-2026, 16:25.
bafische
Karma: +22 / -0   Thank you, like it!
Post02-06-2005, 10:40    Subject: AJM: Torque Map Explained Again Translating...
[Translating...]
Hallo herwigw,
- deine Drehmo ist m.E. original - da wird ja wohl kein Tuner in deinen Wagen eingebrochen haben, damit du dein Leben lang grübelst warum dein Md-Kennfeld krumm ist icon_biggrin.gif - aber man kann ja nie wissen)
- über Ladelufttemperatur gibt es keine Mengenbeschränkung (deswegen ist auch die LLK so wichtig für einen gesunden Motor)
- ausser Höhe gibt es keine Korrekturen für die Drehmo
Der erste Buckel kommt daher dass die Hersteller immer auf einen gleichmässigen Drehmomentverlauf über der Drehzahl achten und da kann sich schon mal aufgrund hydraulischer Unzulänglichkeiten ein nicht linearer Mengenverlauf ergeben. Der zweite Buckel kommt aus der Forderung für die Leitungs-Typprüfung, die besagt, das das Leistungsmaximum bei einer Drehzahl X erreicht werden muss, und bei leicht kleineren/höheren Drehzahlen als X die Leistung abfallen muss.
Dieses Mengenunstetigkeiten wirst du als Fahrer nie spüren, dafür sind sie zu klein. was du merkst ist idR das Ladedruckverhalten - weil das u.a. auch deutlich die Akustik beeinflusst und man meint der Wagen würde in Wellen beschleunigen. Wenn man sich die Ableitung des Drehzahlverlaufes anschaut sieht man das dies aber wirklich nicht der Fall ist.
Wo ist den überhaupt dein Problem?
"Luft und Menge müssen stimmen - der Rest ist Physik."
unumstössliches Gesetz in der Dieselmotorenentwicklung
herwigw
Post02-06-2005, 13:21    Subject: AJM: Torque Map Explained Again Translating...
Wenn es also wirklich eine Korrektur aus einem Überlastungsschutz ist, die mein Drehmo-Kennfeld verbeult, /viewtopic.php?t=9583
also z.B. die Höhenkorrektur - wie Ulf vermutet - oder die Begrenzung aufgrund zu hoher Ladelufttemperatur: Wonach soll ich suchen?
Vergleiche doch erstmal den Verlauf Deiner Drehmo im Log mit meinem Diagramm im anderen Thread.
Wenn Deine Logs unter dem Diagramm liegen, besteht der Verdacht einer Notbremse-Funktion.
Die könnte IMO auch aus zu hohen Wassertemperaturen kommen, aber ich kenne mich da nicht im Detail aus.
Die Ladelufttemperatur ist auch bei 2 Minuten Vollgas im vierten nur knapp an die 40 Grad über die Außentemperatur zu bringen, und der Wert für den Umgebungsdruck zeigt zuverlässig den tatsächlichen Außendruck laut Wetterdienst an.
Zur Begrenzung aus der LLT:
Die beeinflußt bei meinem ASZ nur den Ladedruck oberhalb ca. 75°C (soweit ich das aus den Logs erkennen kann), die Drehmo wird aber nicht geändert.
Bei Vollgas @ 3000 rpm liegt meine LLT noch ca. 35K tiefer, so daß eine LLT-bedingte Drehmoreduzierung (vielleicht ist der AJM ja anders programmiert) erst im hohen Drehzahlbereich greifen dürfte.
Diagramm muß ich noch wertweise vergleichen.
An der Ladedlufttemp wird's also kaum liegen, gut zu wissen dass er auch bei 35 Grad noch ordentlich gehen SOLLTE.
Die Wassertemperatur hatte ich schon mehrmals im Verdacht, konnte aber nix auffälliges finden, das Kühlwasser wird
im Sommer wie im Winter 87 Grad warm und hält die Temp dann stoisch.
Hallo herwigw,
@bafische:
Pfusch Version 0.1 Copyright by VW 2000 icon_smile.gif ?
Ich geh auch davon aus, daß das Auto nie echt oder versuchsweise getunt worden ist, ich war's nicht,
und ob der Vorbesitzer (Pensionist) hat? Trotzdem kann ich es nicht 100%ig ausschließen weil ich bis jetzt
den objektiven Grund nicht gefunden hab, warum der Vorbesitzer ein 3 Jahre altes Auto verkauft -
ich tät sowas nicht!
Das Problem ist, daß man das auf und Ab des Drehmokennfelds genau spürt, vorallem die Täler.
Gerade bei so vergleichsweise schwacher Motorisierung wie meiner, empfinde ich alle Schwankungen in der
Leistungsabgabe beim Überholen als verunsichernd. Im Vergleich dazu hat mein alter 86er 1.8 Liter Otto-Passat
mit einer stoischen Gleichmäßigkeit angezogen, DAS empfand ich als vertrauenerweckend.
Außerdem bin ich inzwischen bei einem Bekannten mit einem AWX Audi mitgefahren, der hatte ab 2000
eine völlig gleichmäßige Beschleunigung - da will ich auch hin icon_smile.gif
gruß Herwig
bafische
Post02-06-2005, 15:24    Subject: AJM: Torque Map Explained Again Translating...
[Translating...]
Hmm, meine Erfahrung sagt mir zwar das du man diese Mengenbuckel fast unmöglich spüren kann, aber irgendwas muss ja dran sein, sonst würdest du ja keine Lösung suchen.
Ein Versuch um die Ladedruckregelung auszuschliessen hätte ich noch anzubieten:
Hintergrund: Beschleunigung bei komplett eingereltem Ladedruck.
Also eine Beschleunigung in den höchsten Gängen aus Leerlaufdrehzahl bis in die Abregelung, am besten die Fahrt mitloggen. Ab spätestens 1700U muss die LD-Regelung stehen, d.h. keine Über-und Unterschwinger mehr. Jetzt kannst du die Linearität der Beschleunigung überprüfen. D.h. wenn du jetzt zwischen 2000-4500U noch irgendwelche Wellen spürst - isses auf keinen Fall die LDR.
Dann bleibt noch die "dünne" Erklärung das deine Hydraulik in diesem Mengen/Druckbereich nicht wirklich linear arbeitet. Das z.B. bei einer gewünschten Erhöhung der Menge um 3mg möglicherweise 5mg wirklich freigegeben werden. Ist aber an den Haaren herbeigezogen.
herwigw
Post03-06-2005, 18:34    Subject: AJM: Torque Map Explained Again Translating...
Wenn ich
Dann bleibt noch die 'dünne' Erklärung das deine Hydraulik in diesem Mengen/Druckbereich nicht wirklich linear arbeitet. Das z.B. bei einer gewünschten Erhöhung der Menge um 3mg möglicherweise 5mg wirklich freigegeben werden. Ist aber an den Haaren herbeigezogen.
Das mit dem komplett eingeregelten Ladedruck ist so eine Sache:
Folgendes Log ( im anderen Thread schon mal gepostet ) - immer die gelbe Linie- ist im vierten Gang gemacht.
http://members.aon.at/835935/050514/08-10.gif
Im dritten schaut's genauso aus egal ob der Ladedruck grad will ...
http://members.aon.at/835935/050516/08_2.gif
oder nicht:
http://members.aon.at/835935/050516/08_1.gif
Mehr als im vierten bis an den Begrenzer trau ich mich hier in Ö nicht,
sonst muß ich ev. ein Weilchen zu Fuß gehen, und meine Drehmomentkurve
fällt mit der Geschwindigkeit noch viel steiler ab und ist bei Hitze
selbst mit Bier-Tuning nur kurzfristig auf akzeptable Werte zu heben icon_wink.gif
bafische
Post03-06-2005, 20:10    Subject: AJM: Torque Map Explained Again Translating...
[Translating...]
Hallo Herwigw,
also im obersten Graph sieht man sehr schön die schwingende LDR.
Das Eintauchen ins Rauch-KF bei dem unteren Graph spricht auch nicht sehr für eine stabile LDR.
Aber ob die schwingende LDR auch für das wellige Fahrverhalten ursächlich ist - ist nur eine Vermutung - mehr fällt mir nicht ein.
Ist das wellige Beschleunigungsniveau bei allen 3 Messungen gleich, oder kannst du das auf einen Drehzahlbereich eingrenzen? Ist es in allen Gängen im gleichen Drehzahlband vorhanden?
herwigw
Post03-06-2005, 21:06    Subject: AJM: Torque Map Explained Again Translating...
Hallo Herwigw,
Hallo bafische,
und ich finde es sehr nett, daß Du Dir Zeit nimmst und nicht müde wirst mich auf den Schmarrn hinzuweisen!
Ich gelobe Besserung, ich werd's beheben - sobald wie möglich - aber können wir die LD-Regelung für den Moment nicht doch außer acht lassen, wenn sie gut genug ist, daß er bei den meisten Versuchen AUSSCHLIESSLICH an der Drehmo hängt?
Apropos: Mir ist noch unklar wie die sogenannte Stellglieddiagnose ( glaub das heißt so ) für das Ladedruckregelventil geht: MWB 011 und auf Grundeinstellung wechseln oder muß man dafür noch was anderes tun icon_question.gif
Wieder zum Drehmo KF und der Einspritzmenge:
Ich IMHO die unterschiedlichen Ursachen für Leistungseinbrüche inzwischen gefühlsmäßig ganz gut unterscheiden:
Gelegentlich Hartes 'Verschlucken' bei ~ 2100 für Rauchbegrenzung.
Weiches 'Nachlassen' für Tal im Drehmokennfeld, bzw freudiges Anziehen für entsprechenden Berg.
D.h. die Berge und Täler der Drehmo sind immer bei den gleichen Drehzahlen zu finden, wurscht wo ich mit dem Beschleunigen beginne. Sie fühlen sich immer gleich an, und ich kann sie auf allen Logs finden seit ich VAG-COM Logs habe(10.2004), also bei Hitze, bei Kälte, bei Trockenheit, bei Regen, mit und ohne verstellter NW-Position...
Für's Wochenende hab ich mir vorgenommen - wieder einmal - alle statischen Werte zu überprüfen ( Bremsbits etc ) und mir die Ausstattungscodierung anzusehen,
vielleicht auch damit herumzuspielen - ist aber nur eine abstruse Idee, ob man mit einer anderen Ausstattungskennung ( Ulf hat sowas einmal versucht und gepostet ) - etwa 5- statt 6-Gang ein anderes Drehmolog kriegt.
gruß
herwig
bafische
Post04-06-2005, 3:50    Subject: AJM: Torque Map Explained Again Translating...
[Translating...]
hallo herwigw,
wenn du ganz sicher bist (und du scheinst es wirklich zu sein) das die träge Beschleunigung nicht im einem Ladedrucktal und die freudige Beschleunigung nicht in einem Ladedruckberg liegt auch wenn du nur in der Drehmo fährst, dann werde ich das Wort Ladedruckregelung nicht mehr in den Mund nehmen. Ehrenwort.
Bei den Codierungen wirst du die Drehmo nicht beeinflussen können, es sei denn du hast ein SG mit mehreren DST und deine Drehmo wurde nur in dem aktuellen DST geändert. Das ist aber auch höchst unwahrscheinlich.
Hast du mal die Volllastmengen mit der von Ulf geposteten Drehmo verglichen? Passt das zu deinen Werten?
Letztendlich weiss ich aber auch nicht weiter. Den Weg zum Chiptuner um dir eine lineare Drehmo einzuspielen, halte ich für unverhältnismässig.
Bei der Stellgliediagnose (oder war es Grundeinstellung?) wird nur die Drehzahl auf 1000U angehoben und das TV des EPW für den Verstellapparat der Turbine von 0 auf 100% im Wechsel gesetzt und die AGR geschlossen. Hier kann man am Ladedruck erkennen ob die Turbine überhaupt verstellt. Spezialisten können aus der Höhe der Ladedruckänderung zwar etwas rauslesen, aber was genau weiss kein Mensch.
Hab leider kein VAG-Com, deshalb weiss ich nicht wie du dahin kommst.
herwigw
Post04-06-2005, 10:34    Subject: AJM: Torque Map Explained Again Translating...
hallo herwigw,
Hallo bafische,
erst jetzt versteh ich Dich möglicherweise erst richtig:
Du vermutest einen Ladedruckeinfluß OBWOHL die Luftmasse ausreichend hoch liegt.
Das stellt dann eigentlich das strikte MaxiMin Prinzip zwischen den Kennfeldern: Immer das niedrigste gewinnt - irgendwie auf den Kopf! icon_question.gif
Gut, dann werd ich mich vorsichtshalber um ein neues N75 umschauen - nur die etwas schwergängige VTG macht mir noch sorgen, jetzt schon bei KM 90.000 den Lader tauschen icon_sad.gif
Vergleich mit Ulf'schem Kennfeld mach ich am So!
Danke erstmals!
Gruß herwig
herwigw
Post06-06-2005, 0:18    Subject: AJM: Torque Map Explained Again Translating...
hallo herwigw,
Hallo bafische,
Danke erstmals!
Gruß herwig
Hallo Ulf und Bafische,
zumindest hab ich jetzt bei zwei Logs die geloggten Werte meines DrehmoKF mit den von Ulf geposteten verglichen: Scheint's ist alles so wie es sein soll,
d.h. mein Bora läuft auf dem normalen Drehmoment Kennfeld und ich hab Euch wahrscheinlich grundlos genervt mit meiner Fehlersuche - tut leid!
Schaut man sich Ulf's Bild genau an, dann kann man den - aus meiner Sicht unverständlichen Buckel bei 4000 auch gut erkennen, ich spür das halt,
aber vielleicht kann ich meinen Perfektionstrieb ja eine Weile damit beruhigen,
daß die bei Volkswagen in Ihrer Weisheit es so gewollt haben, und sie werden schon wissen warum - warum eigentlich wirklich? icon_confused.gif
[Spekuliermodus an]
Wenn sich offenbar bei einem Diesel über ein gewisses Drehzahlband alle Einflußfaktoren
linear verhalten, daß ein aufmerksamer Fahrer jede Abweichung von einer
typischen, dazupassenden linear-sinkenden Mengenbegrenzung genau als Drehmomentberg oder Tal spüren kann,warum zeichnet man dann nicht einfach eine Gerade von 2000 U/min bis 4000 U/min
und rundet die Werte in das verfügbare Kennfeldraster hinein, wenn noch dazu
die Anfangs und Endpunkte durch das gewünschte Drehmomentmaximum bei 2000 und die gewünschte Nennleistung bei 4000 eindeutig bestimmbar sind?
[Spekuliermodus aus]
gruß
herwig
No new posts AJM Torque Curve and Power Delivery Diesel Engine Technology
