donalexo Profi-Schrauber
Joined: 01/08/2003 Posts: 695 Karma: +0 / -0 Location: Würzburg
19-06-2005, 13:09 Subject: LLK Differences: A Comprehensive Guide |
Hello everyone!
Has anyone ever had the opportunity to compare the low-temperature combustion (LLC) characteristics of an AGR, ALH, AHF, or ASV engine (all identical) with those of an ASZ engine?
Since the installation space and the installation conditions are identical, a higher cooling capacity, i.e., a larger surface area, could only be achieved through a more pronounced ribbing of the surface and/or a slightly greater overall depth.
Who knows more details?
How about the mechanical design? Is the ASZ turbocharger mechanically reinforced to better withstand the higher boost pressure?
Does anyone happen to have a picture of the intercooler piping for an ARL engine with a front-mounted intercooler?
Thank you  .
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 29-10-2026, 17:45.
19-06-2005, 16:57 Subject: LLK Differences: A Comprehensive Guide |
donalexo wrote: | Has anyone of you ever had the opportunity to compare the LLK (low-temperature combustion) of an AGR, ALH, AHF, ASV (identical) engine with the LLK of an ASZ engine?
Who knows more precisely? |
Hi Alex,
I can only provide the following information:
The Golf 4 and the Ibiza both have the same (vehicle-specific) intercooler duct for all TDIs up to the ASZ engine, and the G4 uses the same intercooler as the A3.
The A3 has a different cooling air duct for the automatic air conditioning system (ASZ) compared to the other TDIs. In my opinion, this can only mean that the front of the ASZ's evaporator is located further forward, due to a greater cooling circuit depth.
Quote: | | How about the mechanical design? Is the ASZ-LLK mechanically reinforced to better withstand the higher boost pressure? |
I don't know, but the hoses are secured to the ATD (Air Tank Dryer) with spring band clamps, while at the ASZ (Air Suspension Compressor), they are clipped in place with retaining clips – presumably to prevent the hoses from detaching so easily under full pressure.
Translated on 29-10-2026, 17:47.
Profile PM Garage |
Bertil Profi-Schrauber
19-06-2005, 18:20 Subject: LLK Differences: A Comprehensive Guide |
ulf wrote: | ...
but the LL hose is secured to the ATD with spring band clamps, while at the ASZ it is fastened with clips and safety brackets - presumably to prevent the hoses from detaching so easily under full pressure. |
... and my AXR is falling outside the range again...
He also has clips like the ASZ.
Translated on 29-10-2026, 17:50.
19-06-2005, 18:37 Subject: LLK Differences: A Comprehensive Guide |
Bertil wrote: | ... and my AXR is once again out of the ordinary...
He also has clips like the ASZ | .
I wanted to keep that quiet in order not to unnecessarily increase the confusion  .
Translated on 29-10-2026, 17:51.
Profile PM Garage |
Roger Profi-Schrauber
Joined: 10/11/2002 Posts: 3035 Karma: +88 / -0 Location: Rodgau 2017 Volkswagen Golf Premium Support
20-06-2005, 14:16 Subject: LLK Differences: A Comprehensive Guide |
No, the hose clamps are categorized by the year of manufacture, not necessarily by engine type. Also, as far as I know, the ASZ model was initially built with band clamps.
I'm not entirely happy with the quick-release couplings. Without boost pressure, the hoses just hang limply in the connector sleeves, which results in quite a bit of play. In my opinion, this causes the system to automatically drain any remaining oil when parked, as it very slightly leaks from the bottom of the oil cooler in the absence of pressure.
Translated on 29-10-2026, 17:52.
Profile PM Garage |
20-06-2005, 16:02 Subject: LLK Differences: A Comprehensive Guide |
Roger wrote: | | I'm not entirely happy with the hose clamps, but without boost pressure, the hoses just kind of hang loosely in the connectors, and there's quite a bit of play. In my opinion, this results in the system automatically getting rid of any oil residue when parked, by very slightly leaking from the bottom of the oil cooler in the unpressurized state. |
It's possible. There's also some oil leakage at the bottom of the inlet of my LLK, even though the seal seems to be okay.
Translated on 29-10-2026, 17:53.
Profile PM Garage |
matthiasTDI96 Profi-Schrauber
20-06-2005, 21:58 Subject: LLK Differences: A Comprehensive Guide |
Ditto...
Why should my ASZ (local social security office) be different from Roger's?
However, back then, the VW assembly workers incorrectly installed the intercooler hose to the EGR system, which created a significant vacuum.
Translated on 29-10-2026, 17:54.
