Does this control unit fit?
klempnerkai
Post08-06-2005, 10:45    Subject: Does this control unit fit? Quote
I probably wrote that a little too quickly...
Hello, and good day.
I have a question for the community. Since I'm new here, please be kind.
My ACV (Audi/Volkswagen control unit) has a control unit with the part number 074 906 018 AM.
Can I also use a 074 906 018 B with the appropriate reprogramming?
Thank you in advance.
Plumber's Quay.
Translated on 18-10-2026, 20:13.
syncro peter
Post08-06-2005, 11:22    Subject: Does this control unit fit? Quote
Could you please tell me the year of manufacture? What type of file is it? Is there an SG/AG number, for example, SG 3321?
peter
Translated on 18-10-2026, 20:14.
klempnerkai
Post08-06-2005, 11:30    Subject: Year of Construction Quote
Hello Peter,
Year of manufacture or first registration: 2004 / Last Edition. The serial number is currently unknown because the documentation is at home.
syncro peter
Post09-06-2005, 19:21    Subject: Does this control unit fit? Quote
No, that's not possible. The 018B is an 88 hp engine!
peter
klempnerkai
Post12-06-2005, 16:15    Subject: SEO: Best Practices for Website Optimization Quote
Thank you.
It's not possible to simply replace the chip in this control unit and then unlock the rest of the functions like with a GRA (Generic Reset Algorithm).
Okay, then I'll search for the right one.
Thank you very much.
Kai.
Translated on 18-10-2026, 20:15.
Rudi
Post13-06-2005, 8:26    Subject: Does this control unit fit? Quote
Hello Kai,
was ist denn mit dem 018AM? Defective?
The AM data might be running in environment B, but it doesn't necessarily have to be (and the probability is the opposite).
You could use 018C as the ACV data point for the 018B (since 018C is larger).
Rudi
Translated on 18-10-2026, 20:16.
klempnerkai
Post13-06-2005, 8:34    Subject: Does this control unit fit? Quote
Hello Rudi,
Okay. Pin 1 of the chip is missing on the control unit side. But surprisingly, everything still works. This probably happened during repeated chip changes. The problem is, or was, that the boost pressure, despite multiple adjustments and checks, doesn't go higher than 0.8 bar. This isn't just detectable with VAG Com; I also have a display that shows the same thing. If I connect a 20k ohm resistor between the boost pressure sensor, I get 0.9 bar. But that's not the point, since the chip itself should have been modified.
Maybe someone has an idea.
Kai.
Translated on 18-10-2026, 20:17.
Rudi
Post13-06-2005, 9:12    Subject: Does this control unit fit? Quote
Hello Kai,
What have you changed multiple times (or who has been messing around with the file icon_confused.gif)?
800 hPa (or 845 hPa) are the standard values.
Rudi
Translated on 18-10-2026, 20:18.
syncro peter
Post13-06-2005, 10:24    Subject: Does this control unit fit? Quote
It seems someone forgot a lookup table icon_rolleyes.gif.
Do you have the file? If so, please send it to me.
peter
Translated on 18-10-2026, 20:19.
klempnerkai
Post13-06-2005, 13:06    Subject: Does this control unit fit? Quote
I had already suspected that, and that's why I went there, as I know the company's CEO (whose name is 3 letters long). After re-checking the license plate and re-installing the part with increased pressure, it still has the same problem: 0.8...
"I had another chip from a different tuner for this control unit, so I installed it, but still not enough boost pressure. However, it produced less power than the company with the three-letter name. XXX has no explanation for this. When I disconnect and block the hose to the boost pressure control valve, I get excessive boost pressure. So, the system is working correctly, and there are no leaks."
Regarding the car: VW T4 Last Edition with ESP and 102 hp, first registration 04, manufactured 03.
Kai.
Translated on 18-10-2026, 20:20.
Rudi
Post13-06-2005, 13:23    Subject: Does this control unit fit? Quote
If you have the file (or either of the two), could you please send it to me as a private message?
Rudi
Translated on 18-10-2026, 20:21.
klempnerkai
Post13-06-2005, 13:40    Subject: Does this control unit fit? Quote
Hello Rudi,
Since I don't have the equipment to read the chip, I'm unable to do that. I could, at most, send you the chip by mail, as I have three different versions, but none of them affect the boost pressure.
Kai.
syncro peter
Post14-06-2005, 9:01    Subject: Does this control unit fit? Quote
You can also send the chip; no problem.
@rudi
If you have the chip, could you possibly send me the file?
peter
Translated on 18-10-2026, 20:22.
klempnerkai
Post14-06-2005, 15:28    Subject: Does this control unit fit? Quote
Please send me the full address via private message.
By Kai.
syncro peter
Post14-06-2005, 20:04    Subject: Does this control unit fit? Quote
To whom do you want to send the chip?
Do you want my address, or Rudi's?
peter
Translated on 18-10-2026, 20:23.
Rudi
Post14-06-2005, 20:32    Subject: Does this control unit fit? Quote
My not icon_cool.gif.
Rudi
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts How to Read This Control Unit (ECU) On-Board Diagnostics (OBD)
No new posts Is the clutch working properly? Diesel Engine Technology
No new posts Intercooler for A3 with AGR: Will it fit? Diesel Engine Technology
No new posts AAT Cylinder Head: Fits 1T Engine Block? Diesel Engine Technology
