Passed Emergency AU Exam Today?
Manuel Thomas
Post17-06-2005, 17:27    Subject: Passed Emergency AU Exam Today? Quote
I had my vehicle inspection (TÜV) and emissions test (AU) appointment today.
I passed the TÜV inspection without any noticeable defects.
During the subsequent emissions test and the initial free acceleration to test the rev limiter, it went into limp mode. My 17-size turbocharger probably doesn't like free acceleration! I'll have to adjust the variable turbine geometry (VTG) rod again.
'For the three subsequent measurements, I only used a maximum boost pressure of 0.5 bar. The turbidity detected during these measurements was 1.9, which is very close to the limit, and I wonder if the maximum values set by the legislature are not already outdated.'
If a heavily modified AFN engine with 270,000 km on the clock, which has been chip-tuned and is in a limp mode, passes a mandatory emissions test, then the established values are likely not accurate.
Does a EU4 diesel engine actually have a maximum opacity of 2.0?
A final measurement without the engine running showed a turbidity of 0.5. However, since I was controlling the boost pressure with the accelerator pedal, the acceleration time was, of course, incorrect! Therefore, the emissions test was not passed.
Manuel.
Translated on 23-09-2026, 13:16.
Post17-06-2005, 17:31    Subject: AU Exam Passed Today? Emergency Mode. Quote
Manuel Thomas wrote:
However, I still wonder if the maximum values set by the legislature have long been outdated.
Yes... the AU only measures house numbers, anyway.
Also, yes... even DPF vehicles have a maximum permissible opacity of 2.0 icon_eek.gif.
AU = Absolutely Unreasonable.
Translated on 23-09-2026, 13:18.
hb2000
Post18-06-2005, 20:37    Subject: Passed Emergency AU Exam Today? Quote
The whole thing is nothing but a complete mess. Besides costing money, it doesn't really achieve anything worthwhile. They should focus the measurement on CO2 emissions and then base the taxation on that.
Translated on 23-09-2026, 13:19.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG Issues: Emergency Mode, Intake Manifold Pressure Regu... Troubleshooting & Guides
No new posts Doku Touareg, Transmission in Emergency Mode Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Today I was in customer service - read out the measuremen... Diesel Engine Technology
No new posts Golf 6 TDI: VCDS Scan & Review Diesel Engine Technology
No new posts Failed AU Exam: Reasons and Solutions On-Board Diagnostics (OBD)
No new posts Fabia 6Y - MOT failed :( Gasoline Engine Technology
