Control Unit: What it is & How it Works
Golfdriver
Post26-08-2002, 0:40    Subject: Control Unit: What it is & How it Works Quote
Hello.
könnte von nem bekannten seine ********-Chips haben. Nur meinte er, müsste ich erst mal herausfinden ob ich auch 2 Eproms (hoffe das heißt so) habe. Woran kann man das sehen ohne das Steuergerät zu öffnen. Am Baujahr, Steuergerätenummer??? Hab n1995, build month 8 or 9.
Can you tell me what I should be looking for?
Can I have it installed at a VAG workshop?
Hello.
Translated on 28-09-2026, 10:31.
Stefan
Post26-08-2002, 8:26    Subject: Control Unit: What it is & How it Works Quote
forget it.
Almost all devices have two EEPROMs.
'However, the engine control unit number and also the...'
software compatibility.
The number is located on the outside of the control unit.
You can find the software number as a sticker on the two EEPROMs.
Do these data not align (would it really be a coincidence)?
Leave it alone.
Translated on 28-09-2026, 10:32.
Golfdriver
Post26-08-2002, 18:25    Subject: Control Unit: What it is & How it Works Quote
'What would it look like if I installed the entire control unit myself?'
Are there any difficulties?
I have a Golf TDI, and he has a TDI Audi with the same horsepower!
Hello.
Translated on 28-09-2026, 10:33.
zeka
Post27-08-2002, 11:06    Subject: ECU: Steuergerät - Definition und Funktion Quote
Hello.
Please provide the text you would like me to translate from German to English.
and post it.
Then I can definitely help you.
See you, Thomas.
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Central locking control unit in the 8D2 On-Board Diagnostics (OBD)
No new posts ECU and MAF Sensor: Troubleshooting & Repair On-Board Diagnostics (OBD)
No new posts AEL Control Unit and GRA On-Board Diagnostics (OBD)
No new posts Only ABS control unit??? On-Board Diagnostics (OBD)
