[Traduzione in corso...]
Hallo
hier ist der Komplettscan, die Fehler beim Sitzmemory weis ich da nur die Sitze eingebaut sind ohne die passenden Komfortsteuergeräte:
VAG-COM Version: Release 311.2-N
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,17,03,08,15,19,22,37,46,55,56,36,76,47
Address 01 -------------------------------------------------------
Controller: 038 906 019 FE
Component: 1,9l R4 EDC G000SG 1468
Coding: 00003
Shop #: WSC 31414
WVWZZZ1JZ2D346951 VWZ6Z0A4012598
No fault code found.
Address 17 -------------------------------------------------------
Controller: 1J5 920 846 C
Component: KOMBI+WEGFAHRSP VDO V20
Coding: 07114
Shop #: WSC 00000
1 Fault Found:
01300 - Control Module for Navigation with CD-Rom (J401)
49-10 - No Communications - Intermittent
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 H
Component: ESP ALLRAD MK60 0102
Coding: 0023046
Shop #: WSC 31414
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 C
Component: CLIMATRONIC C 2.0.0
Coding: 11000
Shop #: WSC 31414
Address 15 -------------------------------------------------------
Controller: 1C0 909 605 F
Component: 02 AIRBAG VW61 0101 0001
Coding: 12338
Shop #: WSC 31414
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 49120
1 Fault Found:
Address 22 -------------------------------------------------------
Controller: 02D 900 554 C
Component: HALDEX LSC ECC 0009
Address 37 -------------------------------------------------------
Controller: 3B0 919 887 E
Component: Navigation BNO 0202
Coding: 00001
Shop #: WSC 11111
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 B
Component: 1B Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 31414
Address 55 -------------------------------------------------------
Controller: 1J0 941 651
Component: Leuchtweitenregel. V07
Coding: 00002
Shop #: WSC 00001
Address 56 -------------------------------------------------------
Controller: 3B0 035 186 D
Component: Radio BNO 0202
Coding: 32427
Shop #: WSC 17301
2 Faults Found:
00852 - Loudspeaker(s): Front
36-00 - Open Circuit
00853 - Loudspeaker(s): Rear
Address 36 -------------------------------------------------------
Controller: 3B1 959 760
Component: Sitzverstellung FS 0001
6 Faults Found:
01008 - Note: Emergency OFF Switch is Active!
35-00 - -
01328 - Convenience System Data Bus
35-00 - -
01329 - Convenience System Data Bus in Emergency Mode
35-00 - -
01330 - Central Control Module for Central Convenience (J393)
49-00 - No Communications
01331 - Door Control Module: Driver Side (J386)
01332 - Door Control Module: Passenger Side (J387)
Address 76 -------------------------------------------------------
Controller: 1J0 919 283 A
Component: Einparkhilfe 0001
Coding: 00103
Shop #: WSC 00000
Address 47 -------------------------------------------------------
Controller: 1J0 035 456 A
Component: Soundprozessor 3 0004
Coding: 00171
Shop #: WSC 05311
End -------------------------------------------------------
