Verlauf Luftmasse - AHU Motor
dermoe
Beitrag21-06-2010, 21:22    Titel: Verlauf Luftmasse - AHU Motor Zitieren
mein 66kw AHU verliert ab 3200upm kontinuierlich an Luftmasse. Bei 4200upm sind es dann nur noch 750 der 850mgh, bei 4600upm nur noch 650mgh. Der Ladedruck fällt bereits ab 2800rpm, was aber mMn. normal ist.
Ist dieser IST-Verlauf in Ordnung oder sollte ich mir Sorgen um einen zugesetzten Motor/defekten LMM machen?
PS: Der gute hat 270tkm icon_biggrin.gif
Anbei die Log:
Code:
,Group A:,'006,,,,Group B:,'003,,,,Group C:,'010
,,Fahr-,Brems-,Tempo-,keine,,Motor-,Luft-,Luft-,Tast-,,Luft-,umgebungs-,Saugrohr-,Gaspedal-
,TIME,geschwindigkeit,pedal,mat,Anzeige,TIME,drehzahl,masse,masse,verhältnis,TIME,masse,druck,druck,stellung
MARKER,STAMP, km/h,,,,STAMP, /min, mg/R, mg/R, %,STAMP, mg/R, mbar, mbar,%
,63.41,30.0, 0  0  0,  000000,0.0,62.61,1197,320.0,498.8,43.0,63.01,422.3,999.6,1040.4,0.0
,64.61,32.0, 0  0  0,  000000,0.0,63.81,1176,850.0,498.8,4.8,64.21,515.4,999.6,1071.0,100.0
,65.81,39.0, 0  0  0,  000000,0.0,65.01,1386,850.0,585.2,4.8,65.41,645.1,999.6,1244.4,100.0
,67.12,48.0, 0  0  0,  000000,0.0,66.21,1701,850.0,741.5,4.8,66.66,791.4,999.6,1560.6,100.0
,68.51,58.0, 0  0  0,  000000,0.0,67.57,2100,850.0,847.9,4.8,68.05,847.9,999.6,1856.4,100.0
,69.79,68.0, 0  0  0,  000000,0.0,68.96,2478,850.0,847.9,4.8,69.39,847.9,999.6,1999.2,100.0
,70.99,76.0, 0  0  0,  000000,0.0,70.19,2814,850.0,847.9,4.8,70.59,847.9,999.6,1927.8,100.0
,72.19,84.0, 0  0  0,  000000,0.0,71.39,3129,850.0,841.2,4.8,71.79,841.2,999.6,1866.6,100.0
,73.39,91.0, 0  0  0,  000000,0.0,72.59,3423,850.0,804.7,4.8,72.99,804.7,999.6,1815.6,100.0
,74.62,98.0, 0  0  0,  000000,0.0,73.79,3675,850.0,798.0,4.8,74.19,798.0,999.6,1846.2,100.0
,75.95,104.0, 0  0  0,  000000,0.0,75.09,3948,850.0,784.7,4.8,75.55,774.7,999.6,1795.2,100.0
,77.15,110.0, 0  0  0,  000000,0.0,76.35,4179,850.0,764.8,4.8,76.75,758.1,999.6,1795.2,100.0
,78.35,114.0, 0  0  0,  000000,0.0,77.55,4368,850.0,721.5,4.8,77.95,698.3,999.6,1734.0,100.0
,79.55,118.0, 0  0  0,  000000,0.0,78.75,4515,850.0,671.7,4.8,79.15,665.0,999.6,1713.6,100.0
Karma: +432 / -0   Danke, gefällt mir!
Beitrag21-06-2010, 22:52    Titel: Re: Verlauf Luftmasse - AHU Motor Zitieren
dermoe hat folgendes geschrieben:
Ich habe die Werte nicht mehr im Kopf. Aber:
Schau dir die Einspritzmengen in MWB 8 an. Sofern die Einspritzmenge bei Vollgas stets über die Drehmomentbegrenzung und nicht über die Rauchbegrenzung (=Folgerung aus LMM-Messwert) begrenzt wird, ist der LMM ok. Wenn die Einspritzmenge über die Rauchbegrenzung reduziert wird, ist der LMM zu tauschen.
Guste
Keine neuen Beiträge Verlauf (Wechsel) Keilrippenriemen T6 TDI mit Klimaanlage Fehler und Dokumentation (Audi, VW, Seat/Cupra, Skoda)
Keine neuen Beiträge Verlauf Abgastemp. vs. rpm bei Volllast? Diesel Motorentechnik
Keine neuen Beiträge Expertenmeinung zu Ladedruck- und LM-Verlauf gesucht! On-Board-Diagnose (OBD)
Keine neuen Beiträge Ladedruckverlauf und Luftmasse Diesel Motorentechnik
Keine neuen Beiträge Luftmasse zu hoch A6 4F 3.0 TDI ASB Diesel Motorentechnik
