Air Mass Flow Rate - AHU Motor
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
dermoe
Post21-06-2010, 21:22    Subject: Air Mass Flow Rate - AHU Motor Quote
My 66kW AHU is continuously losing airflow from 3200 upm. At 4200 upm, it's only delivering 750 of the 850 m³/h, and at 4600 upm, it's only delivering 650 m³/h. The boost pressure drops already at 2800rpm, which, in my opinion, is normal.
Is this IST value normal or should I be concerned about a clogged/faulty O2 sensor?
PS: The car has 270,000 icon_biggrin.gif
Here's the log:
[code],Group A: '006,,,,Group B: '003,,,,Group C: '010
,,Steering,Braking,Speed,none,,Engine,Air,Air,Touch,,,Air,Ambient,Intake,Throttle
,TIME,speed,pedal,mat,display,TIME,RPM,mass,mass,ratio,TIME,mass,pressure,pressure,position
MARKER,STAMP, km/h,,,,STAMP, /min, mg/R, mg/R, %,STAMP, mg/R, mbar, mbar,%
,63.41,30.0, 0 0 0, 000000,0.0,62.61,1197,320.0,498.8,43.0,63.01,422.3,999.6,1040.4,0.0
,64.61,32.0, 0 0 0, 000000,0.0,63.81,1176,850.0,498.8,4.8,64.21,515.4,999.6,1071.0,100.0
,65.81,39.0, 0 0 0, 000000,0.0,65.01,1386,850.0,585.2,4.8,65.41,645.1,999.6,1244.4,100.0
,67.12,48.0, 0 0 0, 000000,0.0,66.21,1701,850.0,741.5,4.8,66.66,791.4,999.6,1560.6,100.0
,68.51,58.0, 0 0 0, 000000,0.0,67.57,2100,850.0,847.9,4.8,68.05,847.9,999.6,1856.4,100.0
,69.79,68.0, 0 0 0, 000000,0.0,68.96,2478,850.0,847.9,4.8,69.39,847.9,999.6,1999.2,100.0
,70.99,76.0, 0 0 0, 000000,0.0,70.19,2814,850.0,847.9,4.8,70.59,847.9,999.6,1927.8,100.0
,72.19,84.0, 0 0 0, 000000,0.0,71.39,3129,850.0,841.2,4.8,71.79,841.2,999.6,1866.6,100.0
,73.39,91.0, 0 0 0, 000000,0.0,72.59,3423,850.0,804.7,4.8,72.99,804.7,999.6,1815.6,100.0
,74.62,98.0, 0 0 0, 000000,0.0,73.79,3675,850.0,798.0,4.8,74.19,798.0,999.6,1846.2,100.0
,75.95,104.0, 0 0 0, 000000,0.0,75.09,3948,850.0,784.7,4.8,75.55,774.7,999.6,1795.2,100.0
,77.15,110.0, 0 0 0, 000000,0.0,76.35,4179,850.0,764.8,4.8,76.75,758.1,999.6,1795.2,100.0
,78.35,114.0, 0 0 0, 000000,0.0,77.55,4368,850.0,721.5,4.8,77.95,698.3,999.6,1734.0,100.0
,79.55,118.0, 0 0 0, 000000,0.0,78.75,4515,850.0,671.7,4.8,79.15,665.0,999.6,1713.6,100.0
Karma: +436 / -0   Thank you, like it!
Post21-06-2010, 22:52    Subject: Re: Air Mass Flow Rate - AHU Motor Quote
dermoe wrote:
Is this diagnostic log okay, or should I be concerned about a clogged engine/faulty O2 sensor?
I no longer have the values in my head. But:
Check the fuel injection amounts in MWB 8. If the fuel injection amount at full throttle is always above the torque limit and not above the smoke limit (=consequence of the LMM measurement value), then the LMM is okay. If the amount of fuel injected is reduced below the limit, the LMM needs to be replaced.
Greetings
Guste
No new posts Serpentine belt (drive belt) replacement for T6 TDI with ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Leistungsverlust, Luftmasse/Ladedruck/Steuerzeiten ok Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Motor - Motor klappert, Leistungsmangel, Schwarzrauch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Exhaust Gas Temperature vs. RPM at Full Load? Diesel Engine Technology
No new posts Seeking expert opinions on boost pressure and lambda (air... On-Board Diagnostics (OBD)
No new posts Ladedruckverlauf und Luftmasse Diesel Engine Technology
No new posts Air mass too high A6 4F 3.0 TDI ASB Diesel Engine Technology
