Corso di formazione - Motore AHU
dermoe
Messaggio21-06-2010, 21:22    Oggetto: Corso di formazione - Motore AHU Cita
Il mio AHU da 66 kW perde continuamente massa d'aria a partire da 3200 giri/min. A 4200 giri/min, ne perde solo 750 su 850 m³/h, e a 4600 giri/min solo 650 m³/h. Il rapporto di carico diminuisce già a 2800 giri/min, il che, a mio parere, è normale.
È questo andamento del motore normale o dovrei preoccuparmi di un motore bloccato/sensore di ossigeno difettoso?
PS: Il motore ha 270.000 km icon_biggrin.gif
Anbei die Log:
[codice],Gruppo A: '006,,,,Gruppo B: '003,,,,Gruppo C: '010
,,Freno-,Acceleratore-,Velocità-,nessuno,,Motore-,Aria-,Aria-,Tasto-,,Aria-,ambiente-,Tubo di aspirazione-,Pedale dell'acceleratore-
,TEMPO,velocità,pedale,tappetino,display,TEMPO,regime,massa,massa,rapporto,TEMPO,massa,pressione,pressione,posizione
MARKER,STAMP, km/h,,,,STAMP, /min, mg/R, mg/R, %,STAMP, mg/R, mbar, mbar,%
,63.41,30.0, 0 0 0, 000000,0.0,62.61,1197,320.0,498.8,43.0,63.01,422.3,999.6,1040.4,0.0
,64.61,32.0, 0 0 0, 000000,0.0,63.81,1176,850.0,498.8,4.8,64.21,515.4,999.6,1071.0,100.0
,65.81,39.0, 0 0 0, 000000,0.0,65.01,1386,850.0,585.2,4.8,65.41,645.1,999.6,1244.4,100.0
,67.12,48.0, 0 0 0, 000000,0.0,66.21,1701,850.0,741.5,4.8,66.66,791.4,999.6,1560.6,100.0
,68.51,58.0, 0 0 0, 000000,0.0,67.57,2100,850.0,847.9,4.8,68.05,847.9,999.6,1856.4,100.0
,69.79,68.0, 0 0 0, 000000,0.0,68.96,2478,850.0,847.9,4.8,69.39,847.9,999.6,1999.2,100.0
,70.99,76.0, 0 0 0, 000000,0.0,70.19,2814,850.0,847.9,4.8,70.59,847.9,999.6,1927.8,100.0
,72.19,84.0, 0 0 0, 000000,0.0,71.39,3129,850.0,841.2,4.8,71.79,841.2,999.6,1866.6,100.0
,73.39,91.0, 0 0 0, 000000,0.0,72.59,3423,850.0,804.7,4.8,72.99,804.7,999.6,1815.6,100.0
,74.62,98.0, 0 0 0, 000000,0.0,73.79,3675,850.0,798.0,4.8,74.19,798.0,999.6,1846.2,100.0
,75.95,104.0, 0 0 0, 000000,0.0,75.09,3948,850.0,784.7,4.8,75.55,774.7,999.6,1795.2,100.0
,77.15,110.0, 0 0 0, 000000,0.0,76.35,4179,850.0,764.8,4.8,76.75,758.1,999.6,1795.2,100.0
,78.35,114.0, 0 0 0, 000000,0.0,77.55,4368,850.0,721.5,4.8,77.95,698.3,999.6,1734.0,100.0
,79.55,118.0, 0 0 0, 000000,0.0,78.75,4515,850.0,671.7,4.8,79.15,665.0,999.6,1713.6,100.0
Karma: +438 / -0   Grazie, mi piace!
Messaggio21-06-2010, 22:52    Oggetto: Oggetto: Andamento della massa d'aria - Motore AHU Cita
dermoe ha scritto:
Questo percorso di controllo è corretto o dovrei preoccuparmi di un motore bloccato/un sensore di ossigeno difettoso?
Non mi ricordo più dei valori. Ma:
Controlla le quantità di iniezione nel MWB 8. Se la quantità di iniezione al massimo è sempre superiore al limite di coppia e non al limite di fumo (=conseguenza del valore misurato dal sensore di ossigeno), allora il sensore di ossigeno è funzionante. Se la quantità di iniezione viene ridotta al di sotto del limite di fumo, è necessario sostituire il LMM.
Saluti
Gusto
Nessun nuovo messaggio Cinghia di trasmissione a V con denti per T6 TDI con clim... Errori e Documentazione (Audi, VW, Seat/Cupra, Skoda)
Nessun nuovo messaggio Perdita di potenza: massa d'aria, pressione OK? Errori e Documentazione (Audi, VW, Seat/Cupra, Skoda)
Nessun nuovo messaggio AJM Motor - Motor klappert, Leistungsmangel, Schwarzrauch Errori e Documentazione (Audi, VW, Seat/Cupra, Skoda)
Nessun nuovo messaggio Andamento temperatura dei gas di scarico vs. giri/minuto ... Tecnologia Motori Diesel
Nessun nuovo messaggio Si cerca parere di esperti sull'andamento della pressione... Diagnostica di Bordo (OBD)
Nessun nuovo messaggio Ladedruckverlauf und Luftmasse Tecnologia Motori Diesel
Nessun nuovo messaggio Massa dell'aria troppo alta A6 4F 3.0 TDI ASB Tecnologia Motori Diesel
