Zitat: | ,8.14,2310,408.0,938.4,57.2,7.79,35.0,989.4,938.4,0.0,7.96,62.1, ,38.7,84.6
,8.64,2205,193.8,928.2,57.2,8.31,15.0,989.4,938.4,0.0,8.48,62.1, ,38.7,84.6
,9.17,2121,193.8,928.2,57.2,8.81,10.0,989.4,928.2,0.0,8.98,62.1, ,38.7,84.6
,9.67,1974,193.8,928.2,57.2,9.33,0.0,989.4,928.2,0.0,9.50,62.1, ,38.7,84.6
,10.30,1722,193.8,918.0,58.4,9.95,5.0,989.4,918.0,0.0,10.13,62.1, ,38.7,84.6
,10.82,1491,193.8,918.0,60.4,10.47,5.0,989.4,918.0,0.0,10.64,62.1, ,38.7,84.6
,11.34,1239,193.8,601.8,73.0,11.00,0.0,989.4,918.0,0.0,11.17,62.1, ,38.7,84.6
,11.86,1113,193.8,377.4,76.9,11.50,5.0,989.4,479.4,0.0,11.67,63.0, ,38.7,84.6
,12.39,1092,193.8,2193.0,9.9,12.05,15.0,989.4,377.4,0.0,12.22,63.0, ,38.7,84.6
,12.95,987,193.8,2193.0,9.9,12.58,10.0,989.4,2193.0,0.0,12.75,63.0, ,37.8,84.6
,13.47,966,193.8,2193.0,9.9,13.12,10.0,989.4,2193.0,0.0,13.29,63.0, ,37.8,84.6
,13.98,483,1244.4,2193.0,9.9,13.64,10.0,989.4,2193.0,0.0,13.81,63.0, ,37.8,84.6
,14.50,273,193.8,2193.0,9.9,14.16,50.0,989.4,2193.0,0.0,14.32,63.0, ,37.8,84.6
,15.00,0,193.8,2193.0,9.9,14.66,20.0,989.4,2193.0,0.0,14.83,63.0, ,37.8,84.6
,15.55,0,193.8,2193.0,9.9,15.17,0.0,989.4,2193.0,0.0,15.38,63.0, ,37.8,84.6 |
In Deinem Log ist der Sollwert vom Ladedruck 193mbar, der Istwert bei 2193mbar.
Wenn es umgedreht wäre, wäre das noch irgendwie durch interne Schlauchauflösungen oder Venturi Effekte mit folgendem Schlauchkollaps denkbar.
Du hast aber selbst den Beweis gepostet, daß die Sache mit dem "weichen" Schlauch Bullshit ist.
Dein weicher Schlauch mag unschön sein, aber er bringt nicht das Motorsteuergerät dazu, einen Sollwert von 193mbar Ladedruck zu generieren.
Da kommen mir eher Pfuschtuning oder Kabelprobleme/Kurzschlüsse in den Sinn.
