P0237 Signal zu klein, A3 8PA 2.0 TDI | Posts 16+
Go to page: Previous  1, 2
Post09-09-2026, 11:36    Subject: Quote
invade wrote:
It's running again!
The red hose mentioned earlier was it!
"Was ist das?" - what does that mean?
Translated on 09-09-2026, 11:37.
invade
Post09-09-2026, 13:41    Subject: Quote
The remaining three hoses in the charge air system have already been ordered and will be replaced.
Translated on 09-09-2026, 13:41.
invade
Post09-09-2026, 13:44    Subject: Quote
dieselschrauber wrote:
invade wrote:
It's running again!
"Was es" - what does that mean?
To put it another way, this hose was completely soft and I replaced it with a new one. Immediately after the replacement, the engine runs again as if nothing had ever happened.
As a precaution, given the age of the remaining hoses in the charge air system, I'm going to replace those as well.
Translated on 09-09-2026, 13:45.
Post09-09-2026, 15:02    Subject: Quote
,8.14,2310,408.0,938.4,57.2,7.79,35.0,989.4,938.4,0.0,7.96,62.1,,38.7,84.6
8.64, 2205, 193.8, 928.2, 57.2, 8.31, 15.0, 989.4, 938.4, 0.0, 8.48, 62.1, 38.7, 84.6
9.17, 2121, 193.8, 928.2, 57.2, 8.81, 10.0, 989.4, 928.2, 0.0, 8.98, 62.1, 38.7, 84.6
9.67, 1974, 193.8, 928.2, 57.2, 9.33, 0.0, 989.4, 928.2, 0.0, 9.50, 62.1, , 38.7, 84.6
10.30,1722,193.8,918.0,58.4,9.95,5.0,989.4,918.0,0.0,10.13,62.1,,38.7,84.6
10.82, 1491, 193.8, 918.0, 60.4, 10.47, 5.0, 989.4, 918.0, 0.0, 10.64, 62.1, , 38.7, 84.6
,11.34,1239,193.8,601.8,73.0,11.00,0.0,989.4,918.0,0.0,11.17,62.1, ,38.7,84.6
11.86, 1113, 193.8, 377.4, 76.9, 11.50, 5.0, 989.4, 479.4, 0.0, 11.67, 63.0, 38.7, 84.6
12.39,1092,193.8,2193.0,9.9,12.05,15.0,989.4,377.4,0.0,12.22,63.0,,38.7,84.6
12.95, 987, 193.8, 2193.0, 9.9, 12.58, 10.0, 989.4, 2193.0, 0.0, 12.75, 63.0, , 37.8, 84.6
13.47, 966, 193.8, 2193.0, 9.9, 13.12, 10.0, 989.4, 2193.0, 0.0, 13.29, 63.0, , 37.8, 84.6
13.98, 483, 1244.4, 2193.0, 9.9, 13.64, 10.0, 989.4, 2193.0, 0.0, 13.81, 63.0, , 37.8, 84.6
14.50,273,193.8,2193.0,9.9,14.16,50.0,989.4,2193.0,0.0,14.32,63.0,,37.8,84.6
15.00,0,193.8,2193.0,9.9,14.66,20.0,989.4,2193.0,0.0,14.83,63.0,,37.8,84.6
,15.55,0,193.8,2193.0,9.9,15.17,0.0,989.4,2193.0,0.0,15.38,63.0, ,37.8,84.6
In your log, the target value for the boost pressure is 193 mbar, while the actual value is 2193 mbar.
If it were reversed, it might be conceivable that internal hose ruptures or Venturi effects could lead to a subsequent collapse of the hose.
You yourself posted the proof that the thing about the "soft" hose is nonsense.
Your soft hose might look unsightly, but it doesn't cause the engine control unit to generate a target value of 193 mbar of boost pressure. icon_idea.gif
That makes me think more of amateur modifications or cable problems/short circuits.
Translated on 09-09-2026, 15:16.
invade
Post09-09-2026, 15:08    Subject: Quote
Rainer, what can I say?
It runs across the entire RPM range, has power, and won't stall.
I'm just reporting on what I did/exchanged.
There were no foreign objects found in the intake system.
There's no such thing as tuning!
Neither through a lookup table nor through a box, etc.
Translated on 09-09-2026, 15:13.
No new posts Low turbocharger pressure sensor signal error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0101 Error Code: Mass Air Flow Sensor Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts NOx signal too low Diesel Engine Technology
No new posts Exhaust Gas Recirculation (EGR) Potentiometer: Low Signal... Diesel Engine Technology
No new posts Signal too slow, signal too fat 3.0 TDI CTBA Diesel Engine Technology
No new posts AGR throughput too small Diesel Engine Technology
