b.driesen
Joined: 01/10/2007 Posts: 31 Karma: +0 / -0 Location: Duisburg
10-01-2007, 1:31 Subject: Central locking system for Passat Variant 3B 2.5 TDI V6 AFB, manufactured in 1999 |
I'm having the following problem: When I lock the car with the remote, all the doors close. However, the turn signals don't blink. Only on the second or third press of the button.
I know I'm supposed to use the search function. I have done so, and I'm supposed to look for "broken traces" or "cold solder joints" for the following error. However, since my control unit (46) is reporting four errors, I hope someone might be able to immediately say: "Yes, those are the microswitches on the driver's door, or something similar."
Okay, here's the transcript:
Address 46
Control unit: 1J0 959 799 AH
Component: 33 Central SG Comfort Unit 0001.
Encoding: 04097
Shop #: WSC 05311
4 errors found:
00928 - Door lock module for central locking, driver's side (F220)
27-00 - implausible signal.
00912 - Front left window switch (E40)
27-10 - implausible signal - interrupted.
00913 - Window switch for front right window: Driver's side (E81).
00944 - Passenger side mirror heating (Z5)
35-00 - -
Thank you in advance for your replies.
And best regards from the "Ruhr area".
Bernd.
10-01-2007, 9:56 Subject: Central locking system for Passat Variant 3B 2.5 TDI V6 AFB, manufactured in 1999 |
If so many things are happening at the same time with the driver's door, it probably sounds like a broken cable.
What happens if you delete the codes?
Will they come back?
- all of them, immediately.
- sequentially
- one after the other
- in sequence
- sometime, but then all at once.
At the very least, the first and last behaviors strongly suggest a cable break.
Profile PM Garage |
Herr Antje Schrauber
Joined: 01/18/2006 Posts: 1547 Karma: +7 / -0 Location: Nahe Tübingen
10-01-2007, 10:05 Subject: Central locking system for Passat Variant 3B 2.5 TDI V6 AFB, manufactured in 1999 |
Are you having any problems with the interior lighting? Does the interior lighting sometimes turn off even when the door is open or in another unusual state?
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
b.driesen
12-01-2007, 0:01 Subject: Central locking system for Passat Variant 3B 2.5 TDI V6 AFB, manufactured in 1999 |
So,
I haven't had any problems with the interior lighting. I've already cleared the error messages. Whenever I turn the ignition on and off, the error related to the heated mirrors reappears immediately.
The error.
It happens when I lock and unlock the car using the remote control or the key.
The others haven't returned yet. But I remember that the power window for the driver's side door made a strange noise for a short time a while ago.
Okay, so, cleaning the microswitches in the door lock and resoldering the contacts?
12-01-2007, 8:26 Subject: Central locking system for Passat Variant 3B 2.5 TDI V6 AFB, manufactured in 1999 |
b.driesen wrote: | | So, should I clean the microswitches in the door lock and resolder the contacts? |
That's where I'd start, because it's free and microswitches are often the culprit.
Aktuell:
BM Profi-Schrauber
Joined: 12/07/2005 Posts: 1857 Karma: +8 / -0 Location: Nähe Düsseldorf
12-01-2007, 14:20 Subject: Central locking system for Passat Variant 3B 2.5 TDI V6 AFB, manufactured in 1999 |
Quote: | I would start with that, because it costs nothing, and the microswitches are probably often responsible for it.
That's exactly what I would do too. Pay particular attention to properly soldering the connections of pins 7 and 8 (photo), and possibly add a jumper wire.
Most often, contact 7 (at the connector housing) is the cause. This also provides a ground connection for the other three microswitches.
| Description: |
| File size: |
25.01 KB |
| Viewed: |
7960 times |
3B5 AJM
