Vacuum Actuators for Shut-off Valve Needed
Kuhni
Post13-01-2007, 16:23    Subject: Vacuum Actuators for Shut-off Valve Needed Quote
Hello everyone,
I have just experienced an issue while having an AGR (Autologous Grafting Reconstruction) procedure, which involves the placement of a metal plate.
During the disassembly of the EGR valve or other actuator, it broke.
When I removed the vacuum hose, I heard a 'pop,' and the nipple...
It broke off and is still stuck in the hose.
Is the actuator available as a separate part, or do you have to replace the entire AGR valve?
buy a new one? It's attached to the EGR housing with 2 TORX screws.
and the 'arm' can be pried out.
Unfortunately, I couldn't find a part number on the item. The part number is...
The complete AGR valve part number is: 038 129 637.
Providing a part number would be helpful; perhaps I can find it here.
Order USA products from your local, patriotic retailer. Unfortunately, nothing works here without them.
Here's another picture:
http://www.kuhni.at/Bilder/Ansaugbruecke%20Seite.jpg
Regards...
...Kuhni!
Translated on 17-10-2026, 10:59.
Rudi
Post13-01-2007, 16:40    Subject: Vacuum Actuators for Shut-off Valve Needed Quote
Hi Kuhni,
Are you sure about the part number?
'The tool should be available separately (I actually have one lying around at the company).'
It definitely wasn't salvaged from anything. I can provide more details on Monday.
Rudi
Translated on 17-10-2026, 11:01.
Kuhni
Post13-01-2007, 17:22    Subject: Vacuum Actuators for Shut-off Valve Needed Quote
Hi Kuhni,
Best regards, Rudi
Oh, thank you!
The part number is located on the EGR valve (which is actually a single piece of pipe connected to the intake manifold).
attached to it), the actuator itself only bears a date: 05/17/2000.
Perhaps you could also tell me the price.
Thank you.
Kuhni!
Translated on 17-10-2026, 11:02.
Post13-01-2007, 21:26    Subject: Vacuum Actuators for Shut-off Valve Needed Quote
I have an EGR valve left over, "unfortunately" for sale on eBay.
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&ih=006&sspagename=STRK%3AMESE%3AIT&viewitem=&item=160071401371&rd=1&rd=1
Translated on 17-10-2026, 11:03.
Jens 16syncro
Karma: +2 / -3   Thank you, like it!
Post15-01-2007, 6:31    Subject: Vacuum Actuators for Shut-off Valve Needed Quote
Hi Kuhni,
If the EGR channel is already closed, what's the point of having a fully functional EGR valve?
I would simply permanently seal the opening of the membrane pouch and the tube.
Jens.
Translated on 17-10-2026, 11:04.
Kuhni
Post15-01-2007, 7:21    Subject: Vacuum Actuators for Shut-off Valve Needed Quote
Hi Kuhni,
Jens
Hi Jens,
The actuator is responsible for the shut-off valve, which should still be functioning. icon_wink.gif
Regards...
...Kuhni!
Translated on 17-10-2026, 11:05.
No new posts Erwin - Looking for a repair manual for VAG vehicles Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DF 028 906 021: Parking Brake Cover? On-Board Diagnostics (OBD)
No new posts Were there AFN models with a shut-off valve? Diesel Engine Technology
No new posts 1Z with shut-off valve Diesel Engine Technology
No new posts AFB Shut-off Valve Problem? Diesel Engine Technology
