MKB AMF Error Codes: Causes and Effects (Solution)
Michael II
Post01-01-2003, 15:11    Subject: MKB AMF Error Codes: Causes and Effects Quote
Error codes, their causes, and their effects for the AMF MKB, ANY.
Error code: 515
Hall sensor G40, no signal.
Possible causes:
Donor incorrectly attached.
Gap dimension not correct.
G40 failure.
Line interruption or short circuit to ground.
Possible impacts:
longer engine start time.
Signal out of tolerance.
Possible causes:
Hub with damaged or loose axle.
Possible impacts:
Engine won't start.
Engine stopped.
Error code: 671.
Switch for GRA E45, undefined switch state.
Possible causes:
E45 fault.
Power outage or short circuit.
Possible impacts:
No GRA function.
Error code: 741.
Brake pedal monitoring: implausible signal.
Possible causes:
Brake light switch (F) defective.
Brake pedal switch (F47) defective.
Possible impacts:
Preheating lamp is blinking.
Brake light defective.
Error code: 1117
Load signal for generator terminal DF: implausible signal.
Possible causes:
Generator failure.
Voltage regulator faulty.
Power outage.
Possible impacts:
Engine preheating without function.
Error code: 1193.
Relay for low heating power - J359: Short circuit to positive.
Possible causes:
Power outage.
Relay for low heating power - J359.
defective
Possible impacts:
1194
Relay for high heating power - J360: Short circuit to positive.
Possible causes:
Power outage.
Relay for high heating power - J360 is defective.
Possible impacts:
Error code: 1282
Shift valve for throttle control flap N239 - Open circuit or short circuit to ground.
Possible causes:
Power outage.
N239 is defective.
Possible impacts:
Severe engine shutdown.
Possible causes:
Possible impacts:
Error code: 16485.
Air mass sensor G70: Implausible signal.
Possible causes:
G70 malfunction.
Possible effects:
reduced performance.
Black smoke.
Error code: 16685.
Misfire detected in cylinder 1.
Possible causes:
No combustion in cylinder 1.
no compression pressure.
Possible effects:
Uneven engine running.
increased emission levels.
Error code: 16686.
Misfire detected in cylinder 2.
Possible causes:
No combustion in cylinder 2.
Possible effects:
Error code: 16687
Misfire detected in cylinder 3.
Possible causes:
No combustion in cylinder 3.
Possible effects:
Error code: 16705
Crankshaft speed sensor G28: Implausible signal.
Possible causes:
G28 error.
G28 loose.
Crankshaft sprocket loose.
Metal shavings on the G28 or mounting base.
Possible effects:
Engine may stall.
Check light for preheating is blinking.
No indication on the tachometer.
Error code: 16706.
Crankshaft speed sensor G28: No signal.
Possible causes.
G28 error.
Possible effects:
Engine won't start.
Engine stalls.
Error code: 16725
Crankshaft position sensor G40 - implausible signal.
Possible causes:
G40 failure.
Donor incorrectly positioned or not properly secured.
Clearance between the distributor and the camshaft sprocket is not within specification.
Hub with eccentric cam twisted and loose.
Possible effects:
Engine won't start.
Engine stalls.
Error code: 16885.
Vehicle speed signal: implausible signal.
Possible causes.
No signal from the vehicle speed sensor (G22).
G22 failure.
Possible effects:
Speedometer error.
GRA without function.
Air conditioning not working.
The vehicle jerks when shifting gears.
Error code: 16944.
Power supply, implausible signal.
Possible causes:
Diesel injection relay (J322) is defective.
Relay is (sporadically) failing.
Possible effects:
Engine won't start.
Driving behavior defects up to engine shutdown.
Error code: 16946.
Power supply signal too low.
Possible causes:
Power supply below 4V.
Error code: 16947.
Power supply voltage too high.
Possible causes:
Power supply exceeding 20 V.
Error code: 16955.
Brake light switch - implausible signal.
Possible causes.
Possible effects:
Brake lights not working.
Error code: 16989
Control unit J248 is defective.
Possible effects:
Engine shutdown.
Driving behavior deficiencies.
Error code: 17552.
Air mass meter G70: Disconnection/short circuit to ground.
Possible causes:
G70 malfunction.
Possible effects:
Black smoke.
Error code: 17553.
Air mass flow meter G70, short circuit to positive.
Possible causes:
Short circuit to positive _ G70 defective.
Power outage or short circuit after the positive terminal.
Possible effects:
Black smoke.
Error code: 17554.
Air mass flow meter G70, supply voltage.
Possible causes:
Operating voltage too high or too low.
Power outage.
Possible effects:
Black smoke.
Error code: 17563.
Manifold pressure sensor G71: Short circuit to positive.
Possible causes:
G71 malfunction.
Possible effects:
Error code: 17564.
"MAP sensor G71 - Short circuit to ground / Open circuit."
Possible causes:
G71 malfunction.
Possible effects:
Error code: 17565.
Pressure sensor for intake manifold, G71. Power supply voltage.
Possible causes:
G71 malfunction.
Possible effects:
Error code: 17568.
Intake air temperature sensor G72 - short circuit to ground.
Possible causes:
G72 failure.
The wire has a short circuit to ground.
Possible effects:
defaults to a value of 135.9 °C.
Error code: 17569.
Intake air temperature sensor G72 - open circuit/short circuit to positive.
Possible causes:
G72 failure.
Possible effects:
Error code: 17570.
Fuel temperature sensor G81, short circuit to ground.
Possible causes:
G81 failure.
Possible effects:
Error code: 17571.
Fuel temperature sensor G81: Open circuit/short circuit to positive.
Possible causes:
G81 failure.
The wire is short-circuited to the positive terminal.
Power outage.
Possible effects:
Error code: 17663.
Coolant temperature sensor G62, short circuit to ground.
Possible causes:
G62 failure.
Possible effects:
Black smoke during startup.
It is always preheated for approximately 20 seconds.
Error code: 17664.
Coolant temperature sensor G62 - Open circuit/Short circuit to positive.
Possible causes:
G62 failure.
Line interruption or short circuit to the positive terminal.
Possible effects:
Error code: 17668.
Valve for pump/nozzle, cylinder 1, N240 - implausible signal.
Possible causes:
Valve for pump/nozzle cannot be adjusted.
Possible effects:
Error code: 17669.
Valve for pump/nozzle, cylinder 1, N240 - control limit exceeded.
Possible causes:
Time limits are too high.
Transition resistances.
Possible effects:
Error code: 17670.
Possible causes:
Timings are too tight.
Fuel shortage.
Air in the fuel system.
Possible effects:
Error code: 17671.
Valve for pump/nozzle, cylinder 2, N241 - implausible signal.
Possible causes:
Possible effects:
Error code: 17672.
Valve for pump/nozzle, cylinder 2, N241 - control limit exceeded.
Possible causes:
Possible effects:
Error code: 17673.
Valve for pump/nozzle, cylinder 2, N241: Control limit exceeded.
Possible causes:
Fuel shortage.
Possible effects:
Error code: 17674.
Valve for pump/nozzle, cylinder 3, N242 - implausible signal.
Possible causes:
Possible effects:
Error code: 17675.
Valve for pump/nozzle, cylinder 3, N242 - control limit exceeded.
Possible causes:
Possible effects:
Error code: 17676.
Valve for pump/nozzle, cylinder 3, N242: Control limit exceeded.
Possible causes:
Fuel shortage.
Possible effects:
Error code: 17795.
Control unit defective.
Possible causes:
Internal defect in the control unit.
Possible effects:
Engine shutdown.
Error code: 17810.
Exhaust gas recirculation valve N18 - short circuit to positive.
Possible causes:
Possible effects:
No exhaust gas recirculation.
Error code: 17849.
Exhaust gas recirculation (EGR) valve - short circuit to ground.
Possible causes:
Power outage.
Exhaust gas recirculation (EGR) valve failure.
Short circuit to ground.
Possible consequences (in the event of a mass resignation):
Excessive exhaust gas recirculation.
Black smoke.
Error code: 17911.
Load signal from generator terminal DF: implausible signal.
Possible causes:
Generator failure.
Power outage.
Possible effects:
Auxiliary heating system not working.
Error code: 17948.
Vehicle speed signal - signal too high.
Possible causes:
Control panel insert defective.
Possible effects:
Faulty speed display.
Error code: 17954.
Wastegate control valve N75 - short circuit to positive.
Possible causes:
Possible effects:
Boost pressure too low.
Error code: 17957.
Wastegate control valve (N75) - open circuit/short circuit to ground.
Possible causes:
Power outage.
Solenoid valve defective.
Error code: 17958.
Boost pressure regulation differential.
Possible causes:
Boost pressure control valve (N75) defective.
Hoses connected incorrectly, not properly attached, leaking.
Air leak between the turbocharger and the engine (charge air path).
Turbocharger failure.
Possible effects:
Error code: 17964.
Boost pressure control: Limit exceeded.
Possible causes:
Faulty boost pressure control valve (N75), leaky hose connections.
Possible effects:
Error code: 17965.
Boost pressure regulation: Limit exceeded.
Possible causes:
Possible effects:
Boost pressure too high.
Error code: 17977
Switch for GRA E45: Implausible signal.
Possible causes:
E45 fault.
Possible effects:
Error code: 17978.
Engine control unit locked.
Possible causes:
Unauthorized start attempt.
Key.
Manipulation attempt.
Short circuit.
Communication line.
incorrect encoding.
Error in the system.
Drive-away protection.
Immobilizer control unit defective/missing.
Engine control unit replaced and not adapted to the immobilizer system.
Possible effects:
The engine starts and immediately shuts off.
Error code: 18008
Power supply, circuit 15: Voltage too low.
Possible causes:
No voltage detected at ignition terminal (terminal 15).
Possible effects:
Engine shutdown.
Error code: 18009.
Relay for voltage supply, terminal 30, model J317.
Possible causes:
Possible effects:
Engine shutdown.
Engine won't start.
Error code: 18017.
Crash shutdown triggered.
Possible causes:
Airbag deployed.
Actuator diagnostics were performed.
Error code: 18020.
Engine control unit incorrectly programmed.
Possible causes:
Invalid ECU coding.
Possible effects:
Error code: 18024.
Glow plug preheating indicator light - short circuit to positive terminal.
Possible causes:
Possible effects:
K29, function unknown.
Error code: 18025.
Glow plug preheating indicator light - K29 - Open circuit/short circuit to ground.
Possible causes:
Power outage.
Light bulb broken.
Possible effects:
K29 is constantly illuminated (during mass closure).
Error code: 18026
Relay for glow plugs, J52, short circuit to positive.
Possible causes:
Short circuit on the positive terminal, J52 defective.
Possible effects:
No preheating required.
Poor cold start performance.
K29 is blinking.
Error code: 18027
Relay for glow plugs, J52: Open circuit/short circuit to ground.
Possible causes:
J52 error.
Possible effects:
K29 is blinking.
Error code: 18034
Data bus fault: missing message from the transmission control unit.
Possible causes:
Errors in the data lines to the transmission control module (TCM).
Possible effects:
Driving behavior defects.
Load transfer impact.
Shift truck.
Error code: 18039.
Accelerator pedal position sensor (G79) signal too high.
Possible causes:
G79 malfunction.
Possible effects:
increased idle speed.
Error code: 18040.
Throttle position sensor (G79) supply voltage.
Possible causes:
Power outage.
Possible effects:
K29 is blinking.
Error code: 18047
Sensor 1/2 for accelerator pedal position, G79, implausible signal.
Possible causes:
G79 malfunction.
Possible effects:
Error code: 18048
Possible causes:
Possible effects:
Engine shutdown.
Error code: 18062.
Please read the fault memory of the instrument cluster.
Possible causes.
Oil level/temperature sensor defective.
Possible effects:
Oil level warning light is illuminated.
Error code: 18071.
Controlling valves for pump/nozzle: Short circuit to positive.
Possible causes:
Short circuit to positive in the motor wiring harness.
Internal short circuit after positive voltage application in the engine control unit.
Possible effects:
Engine stalls.
The engine is misfiring.
Error code: 18072.
Control of valves for pump/nozzle: electrical fault in the circuit.
Possible causes:
Wiring harness fault, either a broken wire or a short circuit to ground, in the motor cable harness.
Possible effects:
Engine stalls.
Error code: 18073.
Control of valves for pump/nozzle due to mechanical failure.
Possible causes:
Pump-nozzle unit mechanically defective.
Possible effects:
Error code: 18074.
Valve for pump/nozzle, cylinder 1, N240 - electrical fault in the circuit.
Possible causes:
Possible effects:
Error code: 18075.
Valve for pump/nozzle, cylinder 2, N241 - electrical fault in the circuit.
Possible causes:
Possible effects:
Error code: 18076
Valve for pump/nozzle, cylinder 3, N242 - electrical fault in the circuit.
Possible causes:
Possible effects:
Error code: 19459.
Relay for low heating power, J359: Short circuit to positive.
Possible causes:
Power outage.
Relay for low heating power, model J359, is defective.
Possible effects:
Error code: 19461.
Relay for high heating power, J360, short circuit to positive.
Possible causes:
Power outage.
Relay for low heating power, model J360, is defective.
Possible effects:
Error code: 19463.
Crankshaft position sensor G40 - No signal.
Possible causes:
G40 failure.
Possible effects:
Error code: 19464.
Camshaft position sensor G40 signal out of range.
Possible causes:
Hub with toothed wheel on camshaft.
twisted, loose
Possible effects:
Engine won't start.
Engine stalls.
Error code: 19560.
Vacuum switching valve for throttle control, N239 - short circuit to positive.
Possible causes:
Possible effects:
Engine knock.
Error code: 19561.
Vacuum switching valve for throttle control, N239 - Short circuit to ground/open circuit.
Possible causes:
Power outage.
Faulty vacuum control valve for the throttle valve.
Possible effects:
Engine knock.
Tschüss
Michael II
Translated on 26-09-2026, 3:24.
Ratings - MKB AMF Error Codes: Causes and Effects
No new posts Error Codes, Causes and Effects for MKB ASZ, AXR, ATD Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error codes and their causes for MKB AJM, ATJ, AVF, AWX Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error codes and their possible causes for MKB AFN, AVG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LMM Values: Meaning and Impact Diesel Engine Technology
No new posts Defective ZMS: Effects and Troubleshooting Diesel Engine Technology
This topic is locked, you cannot edit or reply. VEP-TDI Nozzles: Available Options & Effects Diesel Engine Technology
No new posts Spurbreite - Auswirkungen aufs Fahrverhalten Transmission, Chassis, Body & Interior
