Doku Lupo 6X1 MJ 2001, Door panel noise (Solution)
Michael II
Post01-01-2003, 16:46    Subject: Doku Lupo 6X1 MJ 2001, Door panel noise Quote
Door/Door Covering and Control Panel Noises
Cause:
In some vehicles, clicking or creaking noises may occur if the lock is forced onto the key cylinder. These sounds can be heard in the B/A column, the door panel, or the control panel.
Solution:
Check with the door handle, after removing the door latch, to see if the noise occurs during driving. If the noise is no longer present, the door latch must be replaced. The door must be re-adjusted. If the noise is still audible after this, the door seal must be checked. Replace if necessary.
Tschüss
Michael II
Ratings - Doku Lupo 6X1 MJ 2001, Door panel noise
No new posts Doku Lupo 6X1 MJ 2001, Dashboard Noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lupo 6X1 MJ 2001: Ventilation Whistle Noise Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Lupo 6X1 MJ 2001, Whistling noise at the doors Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Performance loss Golf TDI PD, Year 2001, 115 hp Diesel Engine Technology
No new posts Install Battery Siren VW G4 MJ 2001? On-Board Diagnostics (OBD)
No new posts Timing Belt Kit for PD AJM 2001 Diesel Engine Technology
This topic is locked, you cannot edit or reply. PDE Changes: Before and After 12/2001 Diesel Engine Technology
