Doku Lupo 6X1 MJ 2000 - Howling noises from timing belt drive (Solution)
Michael II
Post01-01-2003, 16:49    Subject: Doku Lupo 6X1 MJ 2000 - Howling noises from timing belt drive Quote
Whining noises from a toothed belt drive.
Cause:
Vibrations of the timing belt near the water pump.
Solution:
Installation of standard components in case of a complaint:
"Alt:"
Timing belt 030 109 119 M
Tension spring 030 109 243 K.
New:
Timing belt 030 109 119 S
Tension spring 030 109 243 L.
Tschüss
Michael II
Ratings - Doku Lupo 6X1 MJ 2000 - Howling noises from timing belt drive
No new posts Lupo Doku: Door Lock Noises - MJ 2002 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Lupo 6X1 MJ 2001, Dashboard Noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Lupo 6X1 MJ 2001, Door panel noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AC Noisy After G65 Sensor Repair Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Oil in timing chain drive - MKB ABS (Solved) Gasoline Engine Technology
No new posts ALH timing belt drive, oily Diesel Engine Technology
No new posts Timing Belt Audi AAT: Old vs. New Differences Diesel Engine Technology
