A2 Doku: Faulty Combination Light - 8Z0 MJ 2002 (Solution)
Michael II
Post01-01-2003, 17:46    Subject: A2 Doku: Faulty Combination Light - 8Z0 MJ 2002 Quote
Illumination of the switchboard panel is not working or is not functioning as expected.
Cause:
The lighting for the control panel insert is implemented as follows from the factory:
Model year 2000 (Y) and 2001 (1):
A2/A3/A4/A6:
Illumination with headlight activation.
Model year 2002 (2):
TT/A2/A3/A6:
Illumination of the indicators when the ignition is switched on.
Solution:
Vehicles from the 2002 model year:
The lighting can be adjusted via channel 19. The leftmost digit (representing ten thousands) is used for this purpose.
The following applies:
0XXXX - Indicators and scales illuminated when the headlights are turned on.
1XXXX - Indicators illuminate when the ignition is turned on; scales are illuminated when the headlights are switched on.
2XXXX - Scales illuminate when the ignition is turned on; pointer illuminates when the headlights are switched on.
3XXXX - Illuminated pointers and scales that light up when the ignition is turned on.
Note: Do not modify the values for XXXX!
Tschüss
Michael II
Translated on 16-08-2026, 11:13.
Ratings - A2 Doku: Faulty Combination Light - 8Z0 MJ 2002
No new posts Polo MJ 2002: Flickering Lights & CD Player Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4/A6 Doku: Faulty Fan Control System Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 2000: Sun Visor Light Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adapterkabel direkt an Kombiinstr. Rückseite Diesel Engine Technology
No new posts Beleuchtung Diesel Engine Technology
No new posts Illumination of ventilation ducts Transmission, Chassis, Body & Interior
No new posts AC & Lighting: Solutions for Your Comfort Diesel Engine Technology
