Document A2 8Z0 MJ 2002, Air Conditioning Fault 1206 (Solution)
Michael II
Post01-01-2003, 22:51    Subject: Document A2 8Z0 MJ 2002, Air Conditioning Fault 1206 Quote
Error code 01206 is stored in the climate control control unit.
Cause:
Error code 01206 (Signal for ignition off duration - implausible signal) is stored in the fault memory and cannot be cleared after turning on the ignition.
Control panel module reset (automatic reset, for example, due to disconnecting the battery or a drop in voltage).
Solution:
The error can only be cleared after the engine has been started. To do this, start the engine and let it run for at least 30 seconds, then turn off the engine.
Check for errors in the air conditioning system, clear error codes.
Tschüss
Michael II
Translated on 09-07-2026, 2:32.
Ratings - Document A2 8Z0 MJ 2002, Air Conditioning Fault 1206
No new posts Polo MK4 AC Noise: Diagnosis & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A2 8Z0 MJ 2002, Fehler am elekt. Türschloss Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AC Repair: Troubleshooting Common Air Conditioner Problems On-Board Diagnostics (OBD)
No new posts Passat 2002 ABS/ESP Fehler On-Board Diagnostics (OBD)
No new posts Particulate Filter Error 2002 Diesel Engine Technology
No new posts AFN Engine Performance Issues: MJ 1998 Documentation Diesel Engine Technology
