Pfeifen im Standgas | Posts 16+
Go to page: Previous  1, 2
Devilseye503
Post07-02-2007, 17:52    Subject: Quote
A Leon-ARL device with software version 1492 for the HK variant.
Post07-02-2007, 18:08    Subject: Quote
Devilseye503 wrote:
a leon-ARL with the HK variant software 1492
I don't have that, but I do have the 019FK SG1429 and the 019KG SG5342.
Both are not behaving exactly as I described in the loader control: in low gear, they engage at 25%, and when accelerating, they engage at 20%.
If, however, the VTG rod in the LL is still depressible towards the stop by TV 20% , then -> see above.
Devilseye503
Post07-02-2007, 21:07    Subject: Quote
Okay, and that's the case - in the LL (likely referring to a specific engine or system), it's 20% TV (throttle valve opening), and boost pressure is being wasted. Eventually, the boost pressure will build up, leading to overboosts of 2800 mbar (absolute pressure) every time.
That's why I already talked to you about whether shortening it might be a solution.
Post08-02-2007, 9:13    Subject: Quote
Devilseye503 wrote:
that's why I already talked to you about whether shortening it might be a solution?
Under those circumstances (which I was not aware of at the time): yes.
No new posts Transporter 7D Turbocharger Pipes: ACV Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts tdi 1Z; Loud whistling... Diesel Engine Technology
No new posts Whistling with the TDI Diesel Engine Technology
No new posts GTD CFGB Whistles After Startup Diesel Engine Technology
No new posts Turbo Whistle Noise When Accelerating Diesel Engine Technology
