MFA Error: Stop, Brake Failure - User Manual
Stefan OL
Post07-02-2007, 15:57    Subject: MFA Error: Stop, Brake Failure - User Manual Quote
Vehicle: VW Passat Variant 1.9 TDi, 2002, Highline, 121,000 km.
Below approximately 6°C, a continuous three-tone warning sounds after driving through right-hand curves, and the MFA (Multi-Function Display) shows: "Stop - Brake Error - Consult Owner's Manual."
Since I drive our son across the city to school every morning, and there are many right turns along the way, there is unfortunately a lot of annoying beeping in my ears javascript:emoticon('icon_confused.gif')
This error message no longer appears when temperatures are above approximately 10°C.
Does anyone have any ideas?
Translated on 16-10-2026, 18:06.
Post07-02-2007, 16:16    Subject: MFA Error: Stop, Brake Failure - User Manual Quote
Yes.
Find the cause and fix the error.
Check the brake pad wear sensor and wiring coming from the brake pad for shorts to ground. Check the brake fluid reservoir for fluid level. Also, check the secure fit and electrical connection of the connectors.
Translated on 16-10-2026, 18:07.
Herr Antje
Post08-02-2007, 10:12    Subject: MFA Error: Stop, Brake Failure - User Manual Quote
My Passat also had a brake error, but I don't remember the exact message that appeared.
It was the brake wear sensor for me. On one wheel, it wasn't working. I checked it by bridging the individual sensors until the warning message disappeared. Then I measured the wear sensor itself, and there was still continuity. After cleaning the contacts, I no longer have any problems.
I find that curve thing strange. It might not be a faulty wheel sensor. Take a look at what the error memory says.
Aktuell:
- G3 VR6 '93 128 kW, MKB: AAA
Translated on 16-10-2026, 18:08.
No new posts Golf 1J documentary, low-frequency noise from rear brakes Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts µ-Split Brakes: Troubleshooting & Common Issues Transmission, Chassis, Body & Interior
No new posts ABS/ASR Error: Troubleshooting & Solutions Diesel Engine Technology
No new posts Low Brake Fluid: Warning & What to Do Transmission, Chassis, Body & Interior
No new posts 2.0 TDI (BKD) Smoking in Stop-and-Go Traffic Diesel Engine Technology
