ABS Mk60: Zero-Code Functionality?
Frank0_4
Post11-02-2007, 19:00    Subject: ABS Mk60: Zero-Code Functionality? Quote
A hello from the newbie in this super knowledgeable forum!
My questions about the onboarding process:
Is the Mk60 functional in its default state (zero encoding)?
Is the ABS light just indicating the need for a coding procedure, or does it also indicate a system failure?
Can the Mk60 (1K0614517AC) be programmed while it's displaying an error code?
Background:
I cannot clear the ESP errors because the ESP sensors are missing.
I'm only interested in the ABS function!
Sure, here's the translation:
"Thank you in advance..."
Translated on 23-10-2026, 9:14.
