ALH Engine Starting Problems: Troubleshooting Guide
JuFe
Post02-01-2003, 23:02    Subject: ALH Engine Starting Problems: Troubleshooting Guide Quote
I have the following problem with my Golf IV with an ALH engine (90,000 km):
When the engine is cold, it starts perfectly fine. However, if you let the engine run for about 10 minutes and then try to restart it, the engine requires a few more revolutions before it starts.
The difference is very noticeable.
Although the timing belt was recently replaced, it exhibited this behavior even before that.
Can you perhaps help me with something?
Thank you for your help.
P.S. While it doesn't bother me, perhaps this could lead to consequential damages icon_sad.gif.
Jürgen.
Translated on 13-08-2026, 0:16.
Post03-01-2003, 15:15    Subject: ALH Engine Starting Problems - Troubleshooting Guide Quote
JuFe wrote:
If you let the engine run for about 10 minutes and then try to restart it, the engine will require a few more revolutions before it starts.
Although the timing belt was replaced recently, it exhibited this behavior even before.
Hi Jürgen,
Just so you know, mine does that from the factory.
Ist zwar eine ältere Motorgeneration, aber es scheint mir immer wieder so, daß die programmierte Startmenge etwas knapp ist, um alle denkbaran Toleranzen aller maßgeblichen Komponenten bei allen Starttemperaturen so abzudecken, daß der Motor immer auf der 1. Kompression ignites.
It becomes concerning in my opinion when you have to "orgasm" (presumably referring to sexual activity) for a significantly longer time than 1 second – then something might not be working correctly.
For more information, please read the technical article about glow plug systems and starting problems icon_wink.gif.
P.S. While it doesn't bother me, there might be some consequential damages icon_sad.gif
due to that.
I can't imagine anything like that happening – except perhaps that the starter motor won't last forever.
Translated on 13-08-2026, 0:18.
No new posts Occasional starting problems with the Lupo 1.4 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document startup issues, adjusting initial quantity Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Starting problems and glow plug system issues in TDI engi... Technical Articles
No new posts AHF Starting Problems: Troubleshooting Guide Diesel Engine Technology
No new posts T4 2.5 TDI: Starting Problems & Solutions Diesel Engine Technology
No new posts Starting Problems: Troubleshooting & Solutions On-Board Diagnostics (OBD)
No new posts Audi A6 TDI Starting Problems: Common Causes Diesel Engine Technology
