AJM Automatic: Intermittent Idle Surge Issues
BM
Avatar-BM
Post31-01-2007, 21:37    Subject: AJM Automatic: Intermittent Idle Surge Issues Quote
Passat 3B5, year 2000, engine code AJM, automatic transmission, 85,000 km.
Error description:
"When the gear is engaged and the vehicle is stationary, the idle speed occasionally spikes very briefly (approximately 0.5 seconds) to around 1000-1100 RPM, then returns to the normal range at intervals of about 10-20 seconds. It feels like the engine speed drops slightly (barely noticeable) before it spikes, similar to a brief misfire."
All error memory locations are clear. I suspect the temperature sensor may be the issue. Unfortunately, the vehicle was already at 65°C during the diagnosis. The corresponding measured values were plausible. After a test drive and reaching operating temperature, the error could no longer be reproduced.
Does anyone have any ideas?
3B5 AJM
Translated on 01-11-2026, 3:13.
Post31-01-2007, 21:47    Subject: AJM Automatic: Intermittent Idle Surge Issues Quote
Hmm, could it be that, especially if the engine speed momentarily drops, something is drawing power, and that the increased load on the alternator then causes the idle speed to increase?
Translated on 01-11-2026, 3:14.
BM
Avatar-BM
Post31-01-2007, 23:00    Subject: AJM Automatic: Intermittent Idle Surge Issues Quote
Hmm, could it be that, especially if the engine speed momentarily drops, something is drawing power, and that a heavier load on the alternator then causes the idle speed to increase??
Possible, but what is it? I've turned off everything I could. The voltage is a constant 14V. I'll check it again, though.
3B5 AJM
Translated on 01-11-2026, 3:15.
BM
Avatar-BM
Post12-02-2007, 18:12    Subject: AJM Automatic: Intermittent Idle Surge Issues Quote
Plausible, but what?
icon_biggrin.gif Solution: LMM from Herzog icon_exclaim.gif It's unbelievable the kind of errors these things can produce.
Why I overlooked this here: https://community.dieselschrauber.org/en/viewtopic.php?t=12257&start=0&postdays=0&postorder=asc&highlight=herzog is beyond my understanding. icon_eek.gif
"Ergo - if there's nothing sensible written on it, there's nothing sensible inside."
Unfortunately, I couldn't get a Bosch mass airflow sensor (MAF sensor) at that time (Saturday afternoon), which is probably why this happened.
So, stay away from that stuff!
3B5 AJM
Translated on 01-11-2026, 3:16.
No new posts Sporadic PDC issues Electrical Systems, Vehicle Electronics, Multimedia
No new posts TDI Engine: Intermittent RPM Fluctuations BLS 77kW Diesel Engine Technology
No new posts Intermittent power loss on Audi 100 TDi (AAT 115 hp) Diesel Engine Technology
No new posts Audi 100 TDI AAT: Intermittent Power Loss Issues Diesel Engine Technology
