masse motorsteuergerät | Posts 16+
Go to page: Previous  1, 2
Post11-02-2007, 19:33    Subject: Quote
Devilseye503 wrote:
If my statement is not correct, then I would have had to have several ASV engines that were incorrectly wired from the factory icon_wink.gif - I also have a function-specific 1J0 906 627 A part in front of me right now, which behaves 100% the same way.
Funny, my G3 AFN was definitely still "LD-explosion-proof"; I tested that while driving once.
I'll try it out in Ibiza sometime in the next few days, if the weather is good and I remember.
In the Polo, the valves are grouped together in one unit. If I disconnect the connector there, there will be a flood of error messages, possibly with the MIL (Malfunction Indicator Lamp) illuminating because the EGR valve is also affected icon_evil.gif.
If I delete the entries before the (February deadline for the!) technical inspection, the on-board diagnostics (OBD) self-diagnosis is also set to "not completed," and getting it back to "passed" can sometimes be a bit annoying...
which vehicle is around the ARL, I already wrote that last time - Leon icon_lol.gif
If you write it in your signature icon_wink.gif once, no one will ask again.
Translated on 06-10-2026, 2:10.
Post16-02-2007, 17:46    Subject: Quote
Okay, I tried it out at ALH-Ibiza:
Disconnected the plug from the turbocharger solenoid valve, test drive -> no boost pressure buildup, even with full throttle up to 3500 rpm, only 0.1 bar. *Yawn*
Translated on 06-10-2026, 2:12.
No new posts LMM Cable to Ground - Only with ECU Connected On-Board Diagnostics (OBD)
No new posts Engine Control Unit (ECU): Where to Buy? On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Motorola Moto G Power (2022) - Review On-Board Diagnostics (OBD)
No new posts Engine Control Unit (ECU) Help & Search On-Board Diagnostics (OBD)
