Brake light switch, AFB engine
Stefan .
Post05-01-2003, 22:49    Subject: Brake light switch, AFB engine Quote
Hello everyone.
I have a problem with my car (A4/B5 V6TDi Quattro with AFB engine) where I sometimes feel like I'm braking against the engine when switching from the accelerator to the brake.
This manifests as the brakes working as usual initially, but after a few seconds, there's a slight jolt, and you can feel that the engine power is also somehow gone. (It's hard to describe, but I think it's understandable.)
Now, the AFB also features a dual-pedal brake switch, with a normally open and a normally closed contact integrated into a single housing.
IMHO, the device mentioned above has the function of 'disengaging' the engine during braking, so that you don't brake against the engine's force when the clutch is not depressed.
Some time ago, I adjusted the switch a bit during the installation because the brake light was coming on very late (at about half pedal travel), but it didn't really achieve much except for the brake light itself.
Both parts of the switch connect directly to the engine control unit, with one wire branching off to the brake light (normally closed).
My question is:
I read in this forum that an error message is generated when the switch positions are not the same; however, that is not the case for me.
It's possible that this error message isn't intended for this type of switch (since there aren't actually two switches to adjust).
'Has anyone ever experienced a defective switch like this before?'
Mechanically and electrically, everything seems to be in order. However, since the problem only occurs sporadically, it didn't help to disassemble and test the switch.
Or am I completely on the wrong track, and is this perhaps due to something entirely different?
I am grateful for any advice.
icon_wink.gif Stefan.
Translated on 05-07-2026, 14:06.
edazer
Post07-01-2003, 20:46    Subject: Brake light switch, AFB engine Quote
'There are no adjustments that can be made directly on the switch itself. Pull the switch plunger completely out (there is a locking segment inside) and then insert it into the pedal bracket. As soon as you apply slight pressure to the brake pedal, the brake light should illuminate.'
It lights up, and thus also sends a signal to the engine control unit (ECU). This kind of thing happens from time to time. As far as I know, it doesn't cost a fortune.
greetings
edz
Translated on 05-07-2026, 14:09.
No new posts Faulty brake light switch F Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AJM Engine: Rattling, Power Loss, Black Smoke Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 2.0 TDI Engine Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake Light Switch On-Board Diagnostics (OBD)
No new posts Brake Light Switch Wiring Diagram AFN vs 1Z Diesel Engine Technology
No new posts Brake Light Switch Failure: Causes and Fixes Diesel Engine Technology
No new posts Brake Light Switch & Trunk Release - DIY Repair Electrical Systems, Vehicle Electronics, Multimedia
