Biodiesel in 2.5 TDI: AAT Engine Compatibility?
Dirk67
Post08-01-2003, 7:21    Subject: Biodiesel in 2.5 TDI: AAT Engine Compatibility? Quote
Can I use biodiesel (RME) in my Audi A100 C4 2.5 TDI 5-cylinder (AAT) manufactured in 1993?
if not,
Can I modify something so that it will work?
or are you advising me not to go to RME?
(This should not involve any discussion about environmental issues!)
(Differences of more than 10 cents are simply undeniable...)
Translated on 30-08-2026, 4:44.
Post08-01-2003, 9:27    Subject: Biodiesel in 2.5 TDI: Is it safe? Quote
Dirk67 wrote:
Can I use biodiesel (RME) in my A100 C4 2.5 TDI 5-cylinder (AAT) manufactured in 1993?
if not,
No, VW and Audi only switched to fuel lines that are compatible with rapeseed methyl ester (RME) and have been approved for its use starting in model year 1996. However, that's not all; your fuel pump (and the seals associated with it) are not RME-compatible. I cannot tell you what the effects might be on the fuel tank, fuel level sensor, or other components that come into contact with the fuel.
There is no approval from Audi for that model year (and certainly not from Bosch).
... considering the year of manufacture, I wouldn't drive an RME, and whether I would even subject myself to that --- definitely not.
(a difference of more than 10 cents is simply undeniable...)
...and the approximately 10% increase in consumption negates the benefit.
Here's the translation:
"For your information, just as a side note:"
SDI Post Polos do not have RME approval (as of today)!!!!
Why???
"These vehicles have a 'cheaper' Lucas ESP system installed, which RME definitely cannot tolerate!"
Translated on 30-08-2026, 4:47.
No new posts Various errors in my 8K (Audi A4, year of manufacture 2008) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AFN Oil Leak: Causes and Solutions Diesel Engine Technology
No new posts G60 Brake Kit for AFN Engine: Installation & Review Diesel Engine Technology
No new posts Turbo Problems: What's Wrong? Diesel Engine Technology
No new posts TDI Problems: Troubleshooting & Solutions Diesel Engine Technology
