A3 Clutch Squeak: Repair Guide & Troubleshooting (Solution)
Michael II
Post08-01-2003, 11:44    Subject: A3 Clutch Squeak: Repair Guide & Troubleshooting Quote
Squeaking noises only occur in the upper portion of the clutch pedal travel when the clutch pedal is depressed.
Affected vehicle identification numbers:
Until 8L1A091087.
The clutch pedal switch is rubbing against its mounting bracket or the contact surface on the clutch pedal.
Solution.
Check the clutch pedal switch for proper function and, if necessary, apply a thin layer of polyurethane grease (part number: G052 142 A2) to the end of the actuator rod.
Note: The clutch pedal switch is designed for single use only. Repeated installation and removal of a switch will wear down the locking tab.
Tschüss
Michael II
Translated on 27-09-2026, 9:27.
Ratings - A3 Clutch Squeak: Repair Guide & Troubleshooting
No new posts Clutch Squeal: A3 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter 7D: Brake Squeal Noise - Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Dacia/Renault Duster, squeaking noises steering column / ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Thumping at the clutch pedal Diesel Engine Technology
No new posts Clutch pedal squeak Diesel Engine Technology
No new posts Sticking Clutch Pedal: VW Golf G4 PD AXR Fix Diesel Engine Technology
No new posts Clutch Pedal Squeak Golf IV TDI ASZ Transmission, Chassis, Body & Interior
