General Audi customization channels (Solution)
Michael II
Post08-01-2003, 12:21    Subject: General Audi customization channels Quote
Important: Adjustments should only be made if you have the necessary basic knowledge.
Audi, models from the year 2001 onwards, instrument cluster, channel 18.
Structure: XXXXX (five-digit code)
5. Location: Auxiliary heater.
Value 0: No auxiliary heating.
Value 1: Auxiliary heater installed.
Value 2: Auxiliary heating active with terminal 15.
Audi, models from the year 2002 onwards, instrument cluster, channel 19.
1. Subject: Behavior of instrument lighting.
Value 0: The pointers and scales are illuminated when the headlights are turned on.
Value 1: The indicators illuminate when the ignition is turned on, and the scales illuminate when the headlights are turned on.
Value 2: The scales are illuminated when the ignition is turned on, and the needles are illuminated when the headlights are turned on.
Value 3: The pointers and scales are illuminated when the ignition is switched on.
4. Location: Outdoor temperature display.
Value 0: off.
Value 1: on.
5. Location: Radio clock (if installed).
Value 0: off.
Value 1: on.
See also search for "ECU adaptation" or "adaptation channels."
Tschüss
Michael II
Ratings - General Audi customization channels
No new posts General information about PD testing for troubleshooting ... Troubleshooting & Guides
No new posts CR-TDI V6 2.7L: Adjustment Channels Not Working Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
No new posts Audi A6 2.5 TDI (180 hp) Diesel Engine Technology
No new posts Audi A3 8P 3.2 Gasoline Engine Technology
No new posts FIS in the Audi Transmission, Chassis, Body & Interior
