A3 8L Doku: Engine Noise Troubleshooting (Solution)
Michael II
Post08-01-2003, 13:19    Subject: A3 8L Doku: Engine Noise Troubleshooting Quote
Loud noises coming from the engine compartment.
Cause:
By reducing the tightening torque from 25 Nm to 17 Nm for the magnetic coupling connection, the magnetic coupling may become detached from the compressor shaft.
Solution:
Because the loose magnetic coupling is damaging the gears on the compressor shaft, the compressor needs to be replaced.
Tschüss
Michael II
Translated on 10-10-2026, 18:02.
Ratings - A3 8L Doku: Engine Noise Troubleshooting
No new posts Expansion Valve Sounds - A3 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Caddy 9K Rear Axle Noise (1998) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Noises When Turning: Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil everywhere in the engine compartment... Diesel Engine Technology
No new posts Switched plus wire in the engine compartment ?? Electrical Systems, Vehicle Electronics, Multimedia
No new posts Terminal 15, engine compartment / central electronics box Electrical Systems, Vehicle Electronics, Multimedia
No new posts Auxiliary heater and dirt in the engine compartment Transmission, Chassis, Body & Interior
