Cracking noises between the drive/pressure rollers and the seat's longitudinal adjustment rails under extreme load changes.
Affected vehicle identification numbers:
AUZZZ8LZWA000000 - 999999
Cause:
Undesirable material combination of the drive/pressure rollers and the left/right guide rails for longitudinal adjustment.
Solution:
Replace running/pressure rollers.
The union nut should be secured with a locking device. Before loosening the screw connection, heat the union nut with a hot air gun.
D 000 600 A2 Safety device.
1J0 882 260 A Idler rollers.
1J0 882 239 B Driver's seat, left side.
1J0 882 245 B, Driver's seat, left side.
1J0 882 242 B, Driver's seat, right side, also fits the left side.
1J0 882 240 B, Right-hand side control lever, seat. Tschüss
Michael II
Translated on 14-10-2026, 2:35.
