ECU Software Version: Read & Check Now
Otter
Post25-03-2007, 16:40    Subject: ECU Software Version: Read & Check Now Quote
Does anyone know if the software version of a motorcycle's engine control unit (ECU) can be read?
A VAG Com device is available within my circle of acquaintances.
"cu" is a Spanish abbreviation for "con usted," which means "with you." It is often used in online communication to indicate that the sender is available to chat or talk.
Here is an example of how "cu" might be used in a conversation:
Person A: "Hey, I'm bored. Want to chat?"
Person B: "Cu!"
This means that Person B is available to chat with Person A.
"Cu" can also be used to indicate that the sender is thinking about the recipient. For example, if Person A is thinking about Person B, they might send a message that says, "Cu."
In general, "cu" is a friendly and informal way to communicate with someone online.
Translated on 02-10-2026, 11:03.
mullemaus
Post25-03-2007, 16:51    Subject: ECU Software Version: Read & Check Now Quote
It's also listed there icon_wink.gif. If it has a recent update and has been reflashed, it can also be read out. It's located in the top right field.
Sure, here's the translation:
'Zb' is a German abbreviation that stands for 'zum Beispiel,' which means 'for example' in English.
Translated on 02-10-2026, 11:04.
Otter
Post25-03-2007, 18:35    Subject: ECU Software Version: Read & Check Now Quote
It's also on there. With a fresh update and a new flash, it can also be read out. It's located in the top right field.
I'm sorry, but right now I only understand the word "STATION".
I'm not really an expert in this area, so I would appreciate a more detailed explanation, thank you.
Person B: "Cu!"
Translated on 02-10-2026, 11:06.
Post25-03-2007, 19:13    Subject: ECU Software Version: Read & Check Now Quote
Just take a Screenshot of what VAG-COM says in the control unit information section.
No new posts Software updates for Engine Control Unit, Assessment and ... General Tips
No new posts Engine Control Unit Errors: 2.5L V6 TDI (No Delete) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts [Poll] Engine Control Unit (ECU) software version and chip tunin... On-Board Diagnostics (OBD)
No new posts Software Version 038 906 012 AT - Change Diesel Engine Technology
No new posts Software Version: MSG Part Number Lookup On-Board Diagnostics (OBD)
No new posts Audi A3 Software Update: Check & Download On-Board Diagnostics (OBD)
