Alter 2,2l OM615 Mercedes Motor startet schlecht, qualmt | Posts 16+
Go to page: Previous  1, 2
golf3schrauber
Post10-04-2007, 10:03    Subject: Quote
I found something.
The ESP has a control opening on the side. Through this opening, you can access the old oil.
suck up.
It is then topped up with oil until it just starts to leak out of the screw.
Gruss Oliver.
GolfIII,1Z,66KW,von94 mit 500tKm !
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
Translated on 27-08-2026, 17:35.
rodNeX
Post10-04-2007, 12:43    Subject: Quote
Okay, so the Allen wrench size needed there is a 10mm, and that's where you refill it.
until oil leaks out at the rear lower screw.
The screw should be turned out about 3 rotations.
As far as I know, it takes about 400ml of oil.
Best regards, Rodion.
No new posts Document: Audi A4, Engine not starting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 / Audi A3 BKC Engine Failure: Won't Start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P068A Error: Engine Won't Start (Relay J271) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV TDI starts poorly when the engine is warm - DKE i... Diesel Engine Technology
No new posts 1Z is starting poorly Diesel Engine Technology
No new posts Audi A6: Starting Problems with 2.5 TDI Engine Diesel Engine Technology
No new posts ASZ starts warm, runs poorly - what could it be? Diesel Engine Technology
