DrDeca Blaumann
06-04-2007, 12:10 Subject: VAGCOM for Toyota Picnic: Compatibility? |
Hello everyone.
I bought a VAG Com from Rainer a while ago (about half a year). Does anyone know if it can be used with Toyota vehicles?
Specifically, reading error codes and sensor values?
As far as I know, my VAG Com is "tuned" (modified). Where can I get a suitable diagnostic adapter that is compatible with Toyota and works with my VAG Com?
VAG COM Version RKS 607.3-UD
Thank you.
Translated on 09-09-2026, 17:54.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
06-04-2007, 12:43 Subject: VAGCOM for Toyota Picnic: Compatibility? |
If the Toyota supports the OBD2 diagnostic protocol, it will also have the 16-pin OBD2 connector (meaning no adapter is needed).
Simply press the OBD2 button in VAG-COM.
Translated on 09-09-2026, 17:55.
Profile PM WWW Garage |
DrDeca Blaumann
07-04-2007, 11:57 Subject: VAGCOM for Toyota Picnic: Compatibility? |
Hello.
Mmm, I still need to check if it has the same plug. This is my father's vehicle. Let's see - otherwise, I'll get back to you.
Thank you.
DrDeca Blaumann
11-04-2007, 7:04 Subject: VAGCOM for Toyota Picnic: Compatibility? |
It's not working.
The connector fits, but VAG COM indicates that the vehicle may not be OBD-compatible and suggests directly addressing the control units. However, even when selecting the control unit directly (engine control unit), I received no response.
I then tried to read the error codes using a quick scan function, but this also failed because none of the control units responded.
Unfortunately, even the ÖAMTC (ADAC) has failed to solve this problem.
Ideas?
Translated on 09-09-2026, 17:56.
Jochen_145 Guest
11-04-2007, 20:37 Subject: VAGCOM for Toyota Picnic: Compatibility? |
What is the year of manufacture of the Toyota, and is it possibly a diesel?
For diesel engines, the implementation of EOBD2 became mandatory later than for gasoline engines. It was only after 2004 that it became fully applicable to diesel engines with the general EOBD2 regulations.
Before that, it's manufacturer-specific whether a vehicle is generally OBD-compatible or not.
And if the manufacturer doesn't support this, even the best diagnostic adapter won't help.
Best regards, Jochen.
Translated on 09-09-2026, 17:57.
DrDeca Blaumann
12-04-2007, 16:22 Subject: VAGCOM for Toyota Picnic: Compatibility? |
Hi.
The Toyota is a diesel model manufactured in 1999 and equipped with OBD2.
"With OBD1, the error code is indicated by a flashing check engine light, which requires connecting two pins together in the engine compartment. However, that unit is no longer available. Instead, there's a 16-pin diagnostic connector under the steering wheel, which suggests it's definitely OBD2. So why isn't it working?"
Translated on 09-09-2026, 17:59.
Jochen_145 Guest
15-04-2007, 19:55 Subject: VAGCOM for Toyota Picnic: Compatibility? |
Hello, you already have it, don't you?
OBD2 has only been mandatory for gasoline engines since the year 2000. Diesel engines were added later.
Unfortunately, the standardized 16-pin diagnostic connector does not provide any information about the protocol used in the vehicle or its OBD (On-Board Diagnostics) capabilities.
You can find the same component, for example, in a 1994 VW Corrado. At that time, the general OBD standard was still in its early stages of development.
So, a diesel engine from 1999 typically does not support the general OBD2 standard.
Translated on 09-09-2026, 18:00.
