What do you mean by "original value at the start of injection"
The fuel injection start value depends on the engine temperature, fuel injection amount, and engine speed.
The value is normal for idle speed when the engine is at operating temperature.
Would you like to check if the calibration data in the engine control unit (ECU) is still original, or if the ECU may have been modified or tuned? Then, perform a test run at full load, for example, using the MWB 4 8 11 setting.
