Flexible 3C Closing Bolts
Post28-04-2007, 22:34    Subject: Flexible 3C Closing Bolts Quote
HI.
I just filled up my Passat with gas and, of course, started fiddling with everything inside the car.
Is it normal for the latch bolt on the tailgate to be "spring-loaded"?
He's not completely secure, but also not so loose that it seems like it should be bombproof, and 1-2 screws are loose.
It's kind of weird.
Thank you.
Translated on 18-09-2026, 10:48.
rubberduck
Post30-04-2007, 9:49    Subject: Flexible 3C Closing Bolts Quote
Hi Martin,
It's probably because the 3C variant has a power-assisted opening mechanism for the tailgate.
Translated on 18-09-2026, 10:49.
Post02-05-2007, 8:43    Subject: Flexible 3C Closing Bolts Quote
Nope.
The assistance for installing the door is only available if it is a completely electric door.
I saved myself those 400 euros.
rubberduck
Post02-05-2007, 16:13    Subject: Flexible 3C Closing Bolts Quote
I only read it while quickly skimming through the SSP, so I thought.
