helios2000 wrote: |
Now the problem is that the turbo simply stops working at 3000 RPM until it restarts. I've already found out through many forums that there's a hose from the control unit to the engine. It's connected to the control unit, but it's just hanging loose in the engine compartment. Where does this hose need to be connected?
"On my G3 AFN, it was attached to the plastic intake pipe, roughly above the gearbox. There's a nipple there for the hose to connect to."
In your case, when converting from a 1Z to an AFN engine, things might look different...
