Spritzbeginn has changed after 20,000 km, is this normal?
reuselkopp
Post22-05-2007, 16:49    Subject: Spritzbeginn has changed after 20,000 km, is this normal? Quote
Hi everyone,
I was a bit surprised yesterday when I checked my engine data periodically. About 20,000 km ago, I had the timing belt replaced, and at that time, the timing checker showed a deviation of around 55-56. Yesterday, he showed me a starting point of 49-51.
Do I need to worry? Is it normal for the belt to stretch over time, or do I have a problem? Actually, I thought the tension from the rope should be compensated for by the tension roll.
Could it also have been due to the very high temperatures from yesterday? Ambient temperature of approximately 28°C. In the timing checker, the temperature was displayed as 160.
Greetings
Reuselkopp
Golf 4 Variant Modell 05, ASZ mit 330000, ERF Getriebe, mit Zwangskorken, Softwareanpassung von Alex Günther
Golf 3 Variant Modell 98, AFN mit 281000km, ASD Getriebe, VNT15 mit großer Dose, ansonsten alles Original / verkauft
Malte1408
Post22-05-2007, 17:00    Subject: Spritzbeginn has changed after 20,000 km, is this normal? Quote
It is normal that, at high fuel temperatures, it takes longer, because the fuel expands and becomes more compressible.
I would also like to know whether the stretching caused by the clamping roll is being compensated for. Actually, I thought... not icon_question.gif
Post22-05-2007, 17:06    Subject: Spritzbeginn has changed after 20,000 km, is this normal? Quote
Malte1408 wrote:
I would also like to know whether the tension from the winding roll is compensated for. Actually, I thought... not icon_question.gif
It's not balanced because the tension roll is sitting in the empty drum(?)
However, the synchronization between the KW (main line) and the NW (secondary line) runs through the front section -> if the ZR (secondary line) is delayed, the NW is also delayed relative to the KW.
No new posts Doku A3 8P1, Bodenbelag löst sich Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Interior Lights Turn On Late: Troubleshooting Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Do windows open on their own? General Tips
No new posts Einspritzpumpenförderbeginn verändert sich selbstständig Diesel Engine Technology
No new posts Long-term consumption display has changed On-Board Diagnostics (OBD)
No new posts The steering angle at the BRS motor does not change Diesel Engine Technology
No new posts Regelschieberspannung nach Reinigung verändert! Diesel Engine Technology
